Page 461 of 462 FirstFirst ... 361411451456457458459460461462 LastLast
Results 6,901 to 6,915 of 6927
  1. #6901
    Mar 2022
    Hello All,
    Can I request some Help on How to change km on an Aston Martin Vantage 2010?
    the EEPROM is an A82C250, do I need the ST51 like the DB9? or something else?
  2. #6902
    Mar 2013
    Europe
    Check pdf manual
  3. #6903
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by mikasus View Post
    Hello All,
    look here for connection
    https://mega.nz/folder/oMckXRBC#-XvncGXVuDV9VtVGVfMzzw
  4. #6904
    Mar 2023
    I have installed EETOOLS2 and done everything i need to there. My Digiprog 3 is communicating and the dump files are showing up on EETOOLS. When saving the dump files to the PC however, they simply are not showing up in the folder i save them to. Have checked and made sure all hideen files are showing and nothing visible on Windows 10. The files i am saving in the folders however are showing up on EETOOLS.
    Is there a trick that i'm not aware of as to why Windows is refusing to make these files visible or a special way they need to be saved?
    Thanks!
    - Edit
    I've managed to do everything i need on the Digiprog3 itself editing the hex data. Would still be useful to be able to do on PC but no idea why they the dump files are not showing up in windows
  5. #6905
    Quote Originally Posted by sweeetcopcar69 View Post
    Thanks!
    - Edit
    I think files need to be saved as .eep or .e2p if saved as .bin they will not show. I ran into this in the past.
  6. The Following User Says Thank You to AudiS4 For This Useful Post:
    rtbdiagnostic (21st February, 2024)
  7. #6906
    Mar 2023
    Quote Originally Posted by AudiS4 View Post
    Thanks. I did try this already with a few different extensions but i'll try .eep as well. Certainly curious. It's all working great otherwise
  8. #6907
    Nov 2013
    anyone know if it work with prius 2012 and if yes how?
  9. #6908
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by zahoor786 View Post
    About how !
    No obd2 , only remuve / open / desolder .
  10. #6909
    Jun 2011
    Northamptonshire, UK
    Should be a 93c86 if I remember correctly… as Brend has said open back of cluster you usually can do it on the board still but safer to remove it rewrite and replace.
    All in should take about 1hr 30 with removing and replacing the top of the dashboard to get the cluster out.. first few times take a while longer..
    Sent from my iPhone using Tapatalk Pro
  11. #6910
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    Where can i get a ST59 NEC adapter for Digiprog 3 .....
    'If I helped, please click Thanks +Reputation.. !'
  12. #6911
    Aug 2023
    share ur experience....it work on VW after 2007 and ford ,fiat as discribed...???
  13. #6912
    Jan 2024
    Does anyone know what kind of adapter to get for the Digiprog3 to to read/write MSOP8 IC's?
  14. #6913
    May 2015
    My Tool Room
    2012 Land Rover Freelander 2 dash can Digiprog 3 do dash and BSI via obd
  15. #6914
    Apr 2017
    If you have a clone Digiprog 3 and menu selection or entering numbers/digits is either impossible or unreliable, I may have the solution; change the electrolytic capacitors on the PCB. Despite not leaking or bulging some of the caps on mine were way down on capacitance with very high ESR causing a lot of ripple from the switching regulators. After I replaced them all with high quality low ESR capacitors (from a distributor like Digikey, not eBay junk) my device now works perfectly.
    5 x 470uF 25v (these were the worst on mine)
    2 x 47uF 25v
    7 x 22uF 35v
    Just a warning: on my device some of the capacitor pad spacings on the PCB were not quite correct which meant the capacitor leads fall outside the thermal relief area. This makes them difficult to remove as there isn't room to get a large soldering iron bit in, so you will likely need to increase up the iron temperature (assuming you have an adjustable iron).
  16. #6915
    Feb 2024
    Hey all, sorry if this is a dumb questions. I have a kawasaki z800 2013 and I am trying to correct the mileage on the odometer (93C66) will digiprog 3 work for that? And should i worry about disordering the chip from the board? First time doing this any advice will be appreciated!
