Page 462 of 462 FirstFirst ... 362412452457458459460461462
Results 6,916 to 6,920 of 6920
  1. #6916
    Apr 2022
    CAN comunication no work, if someone know what is problem? All relay in obd cable tested works, can ic changed no result.
  2. #6917
    Feb 2024
    Hi everyone,
    is it possible to repair corrupted data after using digiprog 3?
    if it would be necessary to purchase a new dashboard?
    10485824 Internal control module memory check Sum error
    Odometer show only: ------ , in VCDS i see Mileage 16777215 (broken dump after digiprog 3)
    Cluster Nr: 7P6920882M
  3. #6918
    Oct 2018
    Quote Originally Posted by chronicNinja44 View Post
    Hey all, sorry if this is a dumb questions. I have a kawasaki z800 2013 and I am trying to correct the mileage on the odometer (93C66) will digiprog 3 work for that? And should i worry about disordering the chip from the board? First time doing this any advice will be appreciated!
    It can be done. I have already done it. Specify the model in the machine as zzr1400. You can adjust it.
  4. #6919
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by andrejjo View Post
    Hi everyone,
    DP4 , POLDIAG and other elit tool can do this repair obd2 away .
    Find this tool and repair .
  5. #6920
    Dec 2017
    Quote Originally Posted by brend View Post
    You can try read and write with Dp4
    It should repair it
