Page 55 of 462 FirstFirst ... 545505152535455565758596065105155 ... LastLast
Results 811 to 825 of 6920
  1. #811
    Top Poster brkic6's Avatar
    Quote Originally Posted by markony79 View Post
    No, you can not kill dash with OBD
    this happends also with Dp3 on this car
    just pull out battery and return back, everything work fine
    I pulled out battery, but it is so heavy on S-max...
  2. #812
    Any more cars tested with this tool mates?
  3. #813
    I would try but price is a bit to high, maybe some 10 DK users join to me to get this update for
  4. #814
    honingkoning's Avatar
    Dessert
    Quote Originally Posted by cheester View Post
    Mercedes B (w245) with dash plug works great, just 30 second job.
    You need to cut edge of connector.
    Regards Adam
  5. #815
    have test st 60 on W203 year 2005 not working get white screen strange
  6. #816
    Quote Originally Posted by honingkoning View Post
    Regards Adam
    Than I have problem with mine! I had cut edge of connector, but neither A class, ML , or C class did not work for me via connector 60, just say "no connection"!
    Fabia 2001, Zafira 2001 , Astra 2001 , Punto 2001 did NOT worked for me!!!
  7. #817
    batandball's Avatar
    May 2011
    Quote Originally Posted by brkic6 View Post
    Think u got problem with machine m8
    A lot of Merc 203 go via obd
    Astra / zafira depends on type of dash on that year obd
    Punto too early for obd
    Fabia should work obd
    If it works use it
    BatandBall
  8. #818
    Quote Originally Posted by batandball View Post
    When you do mercedes 211 or 203 obd is it flash dash or only does km,because if it only does km should old km take from ezs?
  9. #819
    Dessert
    If your zafira/Astra was vdo it should work.
    I tested on corsa 2001 and went ok.
    I tested punto 2001 reads good milleage but did not change the milleage, but a 2005 punto (old shape) was good.
    I was able to do the 2001 punto with fiat km tool.
    Regards Adam.
  10. #820
    batandball's Avatar
    May 2011
    Quote Originally Posted by antibisic View Post
    If it goes OBD or dash plug then it's only flashing the dash EZS stays the same
    If it works use it
    BatandBall
  11. #821
    Than when you later do ezs new km not count in ezs because off flashing dash,right?Same is e 211 if you do dash by obd ezs not pick up km from dash?
  12. #822
    LANCIA PHEDRA 2002 (CITROEN C8, P 807)
    BSI HC912 OK
    DASH 95020 OK
  13. #823
    celje, slovenia
    laguna 2005- 9s12 ok
  14. #824
    Top Poster binken's Avatar
    Oct 2010
    sweden
    Today i make 1 BMW EWS 3 (OD46J) with ST35 , works perfekt!!
  15. #825
    Does and body have instructiones on how to make ST19?
    Regards,
