Page 63 of 462 FirstFirst ... 1353585960616263646566676873113163 ... LastLast
Results 931 to 945 of 6927
  1. #931
    i tested this pdf and is working ok gray and withe is similar be careful
  2. #932
    Nov 2012
    Quote Originally Posted by xtech View Post
    In the cable White is between gray and black, is not?
    And in the pdf gray is solded with black, thats ok?
  3. #933
    gray and black solder together , in my clone gray color is like withe
  4. #934
    Nov 2012
    In your clone the white is in the middle of black and gray?
  5. #935
    no color is the same
  6. #936
    Nov 2012
    Then,
    is the gray cable the nearest to the black?
    Thanks in advance
  7. #937
    Audi Q7 2007 works ok 30sec. (I accidently used touareg 2004 up menu in digi vigi and it recognized old km and changed no problem)
    Ecu 3.0 tdi wrote no connection. Dp3 cant do it either.
    Focus 2010 10sec ok
    Anyone knows what is best tool for edc16(2.7tdi, 3.0tdi)?
  8. #938
    Quote Originally Posted by nebojsapejcic View Post
    Focus 2010 10sec ok
    for me smok,I did several without problem
  9. #939
    Jul 2011
    sMOK MDX if your looking for the older models, mdcx+ for both old and new
    bkenigma
  10. #940
    anyone try audi a4 m73 dash?works with obd?
    i try but old mileage read only:?? so i dont want to try.
    after try with blue supervag,but after enter old/new mileage nothing happens.
    Finally did with another programmer.
  11. #941
    Mar 2011
    EU
    Somone know if it can change assyst on W203 ?
  12. #942
    batandball's Avatar
    May 2011
    Quote Originally Posted by Ocin View Post
    I think if you look in menu it says service
    If it works use it
    BatandBall
  13. #943
    honingkoning's Avatar
    Dessert
    Quote Originally Posted by solar View Post
    Read all posts and you will find the answer,
    I tried it on a A3 M73 dash (first make backup with upa) than i tried with Digi Prog.
    As i could remember i reads good milleage but does not change the milleage, removed battery for a while and milleage stayed the same.
    Finally changed milleage with good old TU by cluster plug.
    Regards Adam.
  14. #944
    can someone post menu pics??
  15. #945
    Quote Originally Posted by diagnoza_auto2000 View Post
    Not work on CAS4 ,maiby original tool work but not the clone,cause 9S12 adapter is mising
