Page 87 of 462 FirstFirst ... 3777828384858687888990919297137187 ... LastLast
Results 1,291 to 1,305 of 6927
  1. #1291
    dyc's Avatar
    Quote Originally Posted by antibisic View Post
    You made 221 without can filter?
    off course with can filter
    Thanks are welcome !
  2. The Following User Says Thank You to dyc For This Useful Post:
    skrubal (6th December, 2013)
  3. #1292
    Feb 2012
    Quote Originally Posted by sepistar View Post
    on dp3 you can edit the eep lines wich you want and then write back.if you don't know how,please read the manual.
    br.
    Thank you very much for all info's
  4. #1293
    stilo 03 with cable 51 OK,
    CAS2 with direct cas plug connection OK
    CAS3 read crazy mileage something like 23143236,did not try to change(try just for play).
  5. #1294
    mislav88's Avatar
    Mar 2011
    when you tried cas2, did it write unknown version in the dialog box?
  6. #1295
    i think no,i double check in 20min time
    no dont show unknown version,show version:234253(something like this).
  7. #1296
    Quote Originally Posted by solar View Post
    You say CAS3 read crazy mileage was that by OBD or by 4 wire cas plug
  8. #1297
    yes,with 4 wires CAS plug.
    and show INIT error and crazy mileage.
  9. #1298
    When I try with cas plug I get no connection, if u try by OBD let me know results
  10. #1299
    Can u post wiring of your cas plug I.e wire colour and pin on 25 pin connector maybe it wired up different
  11. #1300
    claudio35's Avatar
    Chile
    Mercedes c200 cable 8/9 no works
  12. #1301
    cas plug 35pin(black) to digi 10pin
    cas plug 34pin(green-red) to digi 25pin
    cas plug 26(yellow) to digi 9pin
    cas plug 12(braun-black) to digi 13pin
  13. #1302
    dyc's Avatar
    have you got description of cable 48/2 ?
  14. #1303
    need to do an vito year 2008.what are to expect?as i have never done before.
    br
  15. #1304
    for 48/2 i think this:
    brown pin 13 gnd
    white pin 7 +5v
    green pin 17 Reset
    yellow pin 18 BCKND
    work on 307bsi,no work on rexton dash(did with carprog).more not tested.
  16. #1305
    May 2012
    Uk
    Volvo v70 2011 read write ok and mileage didn't jump back!
