Page 88 of 462 FirstFirst ... 3878838485868788899091929398138188 ... LastLast
Results 1,306 to 1,320 of 6927
  1. #1306
    dyc's Avatar
    Quote Originally Posted by lama23 View Post
    Volvo v70 2011 read write ok and mileage didn't jump back!
    but make mileage tampering fault in instrument cluster
    Thanks are welcome !
  2. #1307
    blackpirate's Avatar
    Jun 2009
    Quote Originally Posted by dyc View Post
    huh?
    what do you mean?
    If freedom is outlawed, only outlaws will have freedom!!!!
  3. #1308
    Quote Originally Posted by sepistar View Post
    need to do an vito year 2008.what are to expect?as i have never done before.
    br
    nobody has done vito 2008??
    br.
  4. #1309
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by blackpirate View Post
    huh?
    what do you mean?
    He is on about someone else tried that same model/year and showed error or tamper dot on dash like BMW I think
  5. #1310
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    br.
    Look at PDF's and try
  6. #1311
    autocargo's Avatar
    I have read from various users that most EDC15-16 not working... Is that right? I only got one to try on...Touran 2005 EDC16 and did not work... Somebody that is using his one more often, what are your experiences? Thanks.
  7. #1312
    huh?
    what do you mean?
    he means that digiprog damage the flash from volvo cars
    and you get error like ex. ignition switch not working ect.
  8. #1313
    dyc's Avatar
    huh?
    what do you mean?
    look at the picture , fault is not eraseble , maybe when cem solution will be known?
  9. #1314
    dyc's Avatar
    Quote Originally Posted by drpeter View Post
    Never had a dot...........
    Verstuurd van mijn GT-N7000 met Tapatalk
    and e60 dot picture after digi3 , so better use other tools for cas
  10. #1315
    Sep 2012
    can about please help me with the PDF file for hyundai i10 thanks
  11. #1316
    batandball's Avatar
    May 2011
    Can I ask you are you using digiprog3 machine for dash and cas ????
    If it works use it
    BatandBall
  12. #1317
    drpeter's Avatar
    The Netherlands
    Default Re: Digiprog 3 clone questions and answers
    Sorry? I did many many bmw cas with digi never had a dot. Maybe you have problems with the dash programming.
  13. #1318
    dyc's Avatar
    drpeter i know your experienced but did also many bmws , after restore backup and program mileage with x912 programmer dot dissapear without touching the cluster ,for cluster always use smok eraser with smok programmer
  14. #1319
    Lithuania , PNV
    i can confirm that
    try with 2 volvo
    carprog reflash this dash ok. without foults
  15. #1320
    carprog?or digi?be a little bit specific.year of the volvos,carprog ori or clone?
    br.
