Page 93 of 430 FirstFirst ... 43838889909192939495969798103143193 ... LastLast
Results 1,381 to 1,395 of 6927
Hybrid View
    Nov 2012
    Quote Originally Posted by shirokov View Post
    VW Golf IV, VW Passat B5, VW Polo 6N, VW T4, VW T5, Skoda Octavia old, Skoda Fabia old, Audi A3/A2/A6/A4 old, etc.
    then now I can understand why I didn't connect with an Audi S3 8L (2000) and a A4 8E (2001).
    Luckily I have the Vag-tacho and CarProg .
    I will try to test with a Golf IV.
    DigiProg III - NEC Programmer - CarProg - Vag-COM - VAG-Tacho - Vag K+Commander - DiagBox - Autocom CDP Plus - Kess V2 - KTAG - FVDI Abrites - OBDProg
    davecooper47's Avatar
    Dec 2010
    I don't think they'll open it up and look for you.
    mislav88's Avatar
    Mar 2011
    peugeot boxer 2007 obd ok 1min
  4. The Following User Says Thank You to mislav88 For This Useful Post:
    shirokov (11th April, 2013)
    56 Lexus IS250 - 93C56 (RA57) - instructions say to take off chip and use ST01 clip using IS250 menu.
    took off chip, connected clip but no IS250 menu, so used IS200 c56 menu instead and it was giving wrong reading.
    tried L460 - RA57/C56 menu and again was giving the wrong mileage same as above.
    put chip in labtool and used tachosoft 23.1 in the end
    Jun 2009
    Toyota Yaris on board with clips -ok, Vectra B 2000 year diag OBD digi says unknown version not ok.
    there is no manual in english ???
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by motorsport View Post
    Use bing translator for translation and nitro PDF to change the files that's what I do
    Discovery 3 2006 OBD 35080 Incorrect mileage read Actual: 119557 / 1924083 Read 2097120
    Peugeot 308 2009 OBD BSI Error- assumed d-sub plug
  10. #9
    Dec 2010
    Discovery 3 will not go OBD anyway. 35080 needs erasing before programming or use a new one.
  11. #10
    Job done with Smok. Thought I would try and read.
    You need to read up on carprog and Enigma's latest updates. Disco 4 too.
  12. #11
    Junior Member centa96's Avatar
    Mar 2013
    Does anyone have experience with Mercedes Vito 108 cdi 2003 year with digiprog3?
  13. #12
    DK Veteran technobox's Avatar
    cyprus
    audi A5 2009 not working
    never lost anythink only change ...
  14. #13
    Lithuania , PNV
    Quote Originally Posted by technobox View Post
    today i try a5 2010 woks perfekt
  15. The Following User Says Thank You to remsia For This Useful Post:
    shirokov (17th April, 2013)
  16. #14
    batandball's Avatar
    May 2011
    Try with A 4 software
    If it works use it
    BatandBall
  17. #15
    pierre renault
    Guest
    Good morning. Anyone know if Digiprog km in 3 changes clio dash NEC (by plug dash) ?
    thank you
