Color ????????
Color ????????
Hi Guys!
I have a Digiprog 3 clone, but without FTDI chip (and without 93c46) - 4.85. And I would like updating to 4.94.
Just i read it on forum the all posts... I buy the FTDi, and the eeprom, and the condensators, and the quartz too. Obstructing. - I have a update software, but I can't install the DP3. - First connect the DP3 of USB, and Windows write me "The device can not be installed because ddl files do not contain information about the device." - Maybe I need any? - Forexampl, the 93c46 need any dump? Or? - Can anybody help me? Or Which DLLs need download for USB contact? I have already kind 2 of dll'. First what have of DP3 updating software, and have a dlls from FTDI.com sites! - But not working the Usb install. :-(
Or easier the update files load on 28f800? :-)
Thank You!
Szinyo (29th May, 2017)
Clusters! EETOOL is it a flash writer? - I have Wellon, this is can 28f800 to write.
The ftdi and the 93c46 soldered, and the 2 pieces 100nF condensator, ant the 6.000MHZ quartz soldered too! - But have not contect on USB. :-(
Szinyo (30th May, 2017)
hi
toyota lancruser 2010 cs86 ! on eeprom ok
regards
Please dear members push the button thanks and reputation button(stars)
do you need help? fill it in !!!
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
ECU type and number:
Memories :
https://www.digital-kaos.co.uk/forum...63#post1660863
rtbdiagnostic (29th May, 2017)
Memet99600! - I installed eetool. - But eetool write me "Device not found". - I think I have any problem with FTDI chip. Because i connect the DP3, then the windows write me: "The device could not be installed because the device could not be identified". Still one need buy a new ftdi chip, and try.
I think easier the update files uploading to 28f800, and ready.
Thank You.
Hello, I have the same problem with my FTDI chip, when I search in internet I see the new driver 2.12 brick FTDI chip, so I buy a small evaluation board with the same FTDI chip, I try it, work perfectly, after I swap the 2 FTDI chip now works perfectly.
You have to download FTprog (I don't remember the name excat) and your vid: 0403 and pid: 6001
If it's not like this your chip is bricked, so you need to change it.
If I help you don't forget thanks button
hello guys
i just bought a digiprog3 with the latest update now can someone show me how to do the honda pilot 2007 and up as well as ford f150 2005 and up please thank you guys
latest update is 5.03, I think you just have 4.94 :P
for pilot:
open cluster, look for eeprom 93c56 or 93c66 or 93c76 on circuit board. connect cable 01.
i dont think there is 'pilot' in the menu of honda. choose any other model (for example honda jazz) if it shows the same chip number. if it reads mileage correct then you can proceed and enter new mileage.
for f150 check your manual, you need to solder some wires on circuit board
Perfect nicolas9 great i did used before a tacho pro and didnt work but let me try with another one with the eeprom should i do something different?
