Page 440 of 462 FirstFirst ... 340390430435436437438439440441442443444445450 ... LastLast
Results 6,586 to 6,600 of 6917
  1. #6586
    Oct 2018
    Quote Originally Posted by letalcrudo View Post
    dude. I've got digiprog 3 and I use it for OBD2 work only. start taking the eeprom out from pcb. clips sometimes corrupt data
    So it is better to out it out and work?
    If the data corrupted what shall I do?
  2. #6587
    Feb 2017
    Baltic
    look for dump from another car or buy new dash
  3. #6588
    Oct 2018
    Toyota alphard 2010 93a66 digiprog can't read which tool can i use
  4. #6589
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by woodytech5 View Post
    how do you mean canīt read...?
    post a photo... what digiprog show you on display...?
    when I helped you press Thanks and Reputation
  5. #6590
    Oct 2018
    Quote Originally Posted by mikkhh View Post
    So could you please send me the dump file please
  6. #6591
    Aug 2015
    Quote Originally Posted by Kimoo200k View Post
    Hello my friends
    I want to Eeprom hiace cluster becuase it give me 9999999
    and I want to change it to counter again
    What shall I do?
    I use st01 cable but the chip no read and if it read it gives me 0 value and when I change nothing happen
    Please help me
    Thanks in advanceAttachment 567636
    If you are getting a reading of 0 km the clip is not connected properly it’s either a broken wire or not correctly made which is very often the case with those cheap clips !!!
    Thos
  7. #6592
    Oct 2018
    Quote Originally Posted by Thos View Post
    Thos
    When I use toyota hiace give me 0 km and sometimes chip not found
    but when I use hilux it read and write but no change in car
  8. #6593
    Aug 2015
    2 questions for you -
    When it reads with hilux does it read the correct km that is on it ?’
    For example if you input new km at 80133km does it come up with 80$&&km or does it show a different number maybe a few thousand different ?
    You have to clean the eeprom 110% for it to read incurcuit that will be the source of your problem
    thos
  9. #6594
    Oct 2018
    thos
    Thanks for quick answer
    It show a diferent just few thousand km for example I input 100000 it give me 1000117
  10. #6595
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    100000 to 1000117 is more than a few thousand and is too much maybe approximately 20 is ok
  11. The Following User Says Thank You to teerak2uk For This Useful Post:
    Kimoo200k (6th November, 2018)
  12. #6596
    Oct 2018
    Quote Originally Posted by teerak2uk View Post
    Is this ok ?
    When I use hilux on hiace cluster
    Or my hiace cluster dump damaged?
  13. #6597
    Is this digiprog 3 from obd2cartool any good..?
    They have option 1 and 2 but don't understand what the difference is between the 2... Not stated in ad very well...
    Thank you
  14. #6598
    May 2017
    Hi. I have a problem with digiprog 3 v4.94 in BMW Cas 3. When I turn on the scan at the end of the scan after the scan should appear, an unknown version appears. What's the problem ?
  15. #6599
    Quote Originally Posted by kotarski88 View Post
    The problem is simple its unknown version. U need to remove cas and do direct
    Sent from my SM-N960F using Tapatalk
  16. #6600
    May 2017
    OK I understand. And there is a version at all that makes cas 3 by OBD2
