Page 441 of 462 FirstFirst ... 341391431436437438439440441442443444445446451 ... LastLast
Results 6,601 to 6,615 of 6917
  1. #6601
    Dec 2017
    Default Digiprog 3 clone questions and answers
    Some can be done and some have to be out
  2. #6602
    Feb 2013
    Lithuania
    digiprog 2017 vw multivan do it or not? touran 2014 do it 100%.
  3. #6603
    Oct 2018
    this my eeprom it is
    This is my eeprom only read when i use hilux but the dashboard give me different mileage i give for example 100000 it give me 1000017
    When i use hiace 46 it give me 0 km and if i edit give me 3456789
    I don't what's wrong i really fed up!
    Ic as photo
    My part number is 7G9H31116A3 please help me
  4. #6604
    letalcrudo's Avatar
    Nov 2015
    Canada
    Quote Originally Posted by Kimoo200k View Post
    dude. edit that eeprom out PCB and job will be ready in 10 minutes.
  5. The Following 2 Users Say Thank You to letalcrudo For This Useful Post:
    jomberykaso (10th November, 2018), Kimoo200k (10th November, 2018)
  6. #6605
    Oct 2018
    Quote Originally Posted by letalcrudo View Post
    Please tell me step by step
  7. #6606
    Jun 2013
    Desolder eeprom and read
    Wysłane z mojego SM-G390F przy użyciu Tapatalka
  8. #6607
    Oct 2018
    Quote Originally Posted by wbart View Post
    Thanks bro
    But i need dump for it
  9. #6608
    Jul 2018
    Quote Originally Posted by Edvardas View Post
    I Tried Already to change the odometer for Touran 2014 But Not Work With Me How To Do Pease ?
  10. #6609
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Quote Originally Posted by Anass GM View Post
    Most VW 2014 Will not work.
    After June will definitely not work
  11. #6610
    Oct 2018
    Does my clone work with BMW E60 2006?
    Thx
  12. #6611
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by zweb007 View Post
    Thx
    As I know cas3(+) can not be done with your tool...
    but you could do it with an emulator on cas...
    and dash with new chip...
    so at the end it can be done...
    When I helped you press Thanks and Reputation...
  13. The Following User Says Thank You to figani For This Useful Post:
    zweb007 (25th November, 2018)
  14. #6612
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Quote Originally Posted by figani View Post
    Emulator not possible for cas3.
    To do cas you need r270 or r260.
    Digiprog can do cas3+ by obd (unless updated by dealer), but 2006 is cas3 (or cas2 if late 2005)
  15. The Following 2 Users Say Thank You to Nicolas9 For This Useful Post:
    figani (14th November, 2018), zweb007 (25th November, 2018)
  16. #6613
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    need advice can digiprog read / erase and write the 95320WT chip found in the ford Transit - is WT maybe also write protect
    'If I helped, please click Thanks +Reputation.. !'
  17. #6614
    Oct 2018
    ok and how can I find type of CAS installed on car ? It's a late 2005 as I know.
  18. #6615
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Probably a cas 2 scan it a check part numbers or remove and look
  19. The Following User Says Thank You to teerak2uk For This Useful Post:
    zweb007 (23rd June, 2021)
