Page 53 of 462 FirstFirst ... 343484950515253545556575863103153 ... LastLast
Results 781 to 795 of 6927
  1. #781
    Dec 2009
    Prussia
    Quote Originally Posted by carradio2001 View Post
    DP3 Menu for Audi A4 :
    Carradio2001.
    what a nifty little chart.
    Can you upload the complete one please?
  2. #782
    Sep 2009
    Does anyone know what lead ST79 is used for?
    Don't forget to hit thanks button
  3. #783
    carradio2001's Avatar
    Nov 2009
    France
    Quote Originally Posted by TULGEYWOODMAN View Post
    Send me your e-mail address via pm.
    Carradio2001
  4. #784
    Nov 2012
    hello
    Does anyone know what lead ST62 for cas diag bmw ?
  5. #785
    bmwparts's Avatar
    Apr 2010
    RSA (where men are men and sheep are nervous)
    Lead ST62 is supposed to conect to the dash plug going to the cluster on E60 E90 E65 to programme the CAS. E65 uses a different connector than the others. I would however not attempt to use clone to do this as the E65 CAS can be damaged if the wrong socket is used. I dont know which socket is which.
  6. #786
    Nov 2009
    France
    Lead ST62 is NOT provide with Digiprog. I think this option will not work !
    Carradio2001.
  7. #787
    Nov 2012
    Quote Originally Posted by bmwparts View Post
    in conclution; the fonction cas diag not works in digiprog 3 in bmw. yes or no?
  8. #788
    Apr 2012
    Quote Originally Posted by bouekkazine View Post
    I believe same suppliers say :
    BMW 1er / E81/E82/E87/E88 CAS3 Diagnostic OBD
    BMW 3er / E90/E93 CAS3 Diagnostic OBD
    BMW 5er / 60/E61 CAS3 Diagnostic OBD
    BMW 6er / E63/E64 CAS3 Diagnostic OBD
    BMW X5er / E70 CAS3 Diagnostic OBD
    BMW X6er / E71 CAS3 Diagnostic OBD
  9. #789
    batandball's Avatar
    May 2011
    This is the one that came with mine
    If it works use it
    BatandBall
  10. #790
    bmwparts's Avatar
    Apr 2010
    In short I have yet to successfully do a CAS unit with the clone. I have also tried the HC12 cable, which I got from repsoft which also doesn't work with the clone.
    If things seem under control, you are simply just not going fast enough!!
  11. #791
    bmwparts's Avatar
    Apr 2010
    Tried to do EZS unit on Merc Vito with no success had to use original DigiProg
  12. #792
    Dec 2009
    Prussia
    Is it not risky trying a 9s12 [or 908 ]with a clone when you have the original?
  13. #793
    bmwparts's Avatar
    Apr 2010
    Is rather but only one way to find out what it can do. Original is not same s/w version as clone so the clone is able to do a lot more vehicles than original.
  14. #794
    Apr 2012
    Default w203
    hello
    is there anyone who knows how to use the cable 49 for the W203 ?
  15. #795
    batandball's Avatar
    May 2011
    Quote Originally Posted by saadoun View Post
    hello
    Don't use that cable press x on the box when it tells you that cable then it should tell you another cable number 16 which is OBD lead or another number which is cluster plug
    have not got machine here so i cant tell u cluster plug number
    If it works use it
    BatandBall
