Page 97 of 462 FirstFirst ... 47879293949596979899100101102107147197 ... LastLast
Results 1,441 to 1,455 of 6927
  1. #1441
    Sep 2009
    Quote Originally Posted by autocargo View Post
    Thank you briangsm. Does digiprog working good on EZS HCS12? Have you done any? I don't remember to have seen any adapter with coaxial cable in my adapters... is there one? Is it safe on this EZS? Regards.
    No digiprog doesn't work as there is no adapter in package
    Don't forget to hit thanks button
  2. #1442
    bmwparts's Avatar
    Apr 2010
    RSA (where men are men and sheep are nervous)
    Even if you have the adapter it still does not work.
    If things seem under control, you are simply just not going fast enough!!
  3. #1443
    Jun 2010
    Quote Originally Posted by bmwparts View Post
    Original is also bad with ezs and cas
  4. #1444
    davecooper47's Avatar
    Dec 2010
    I have 2 digiprogs. Both work ok for OBD but one of them will not read all eeproms. One of them is fine but the other will only read 95xxx eeproms and not 93cxx or 24cxxx. I suspect there is something wrong with the buffer chips (hc125's etc). The problem is that all of the chips have had the tops ground off so I don't know which chips to change. Can someone help me with this please.
  5. #1445
    pierre renault
    Guest
    help me. digiprog 3 per OBD does not work! experienced in seat toledo 2000 not working
    Information: ERROR NOT CONNECTION
    Once again, sorry correction in colors and 9-pin plug
    plug 9 pins
    1 whit
    2 green
    3 red
    4 orange
    5 yellow
    6 not connect
    7 blue
    8 purple
    9 gray
  6. #1446
    Apr 2010
    LT & ES
    Vw Jetta 2008 : dash OBD - ok,
    edc 1,9 OBD - unknown version,
    DSG was 411k with reset got 514k ??? and no way to change back,
    Service OBD - ok
    Faults OBD - ok
  7. #1447
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by pierre renault View Post
    plug 9 pins
    1 whit
    2 green
    3 red
    4 orange
    5 yellow
    6 not connect
    7 blue
    8 purple
    9 gray
    Search this thread I posted pics for changing serial connection with pin numbers the 9 pin is normally where the problem is
  8. #1448
    Dec 2008
    pin 9 is not connected mate ???
  9. #1449
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by u.s View Post
    I mean problem is normally in the 9 pin serial connection ( serial plug) not pin number 9
  10. #1450
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    plug 9 pins
    1 whit
    2 green
    3 red
    4 orange
    5 yellow
    6 not connect
    7 blue
    8 purple
    9 gray
    Do cable like I did here with new serial plug
    http://www.digital-kaos.co.uk/forums...ml#post1894332
  11. #1451
    pierre renault
    Guest
    I DID THE TEST WITH MULTIMETER CONTINUITY OF PIN 9, THE SOLDIERS OF WIRES AND PLUG OBD CONTINUED!
    STILL THINK YOU SHOULD CHANGE THE PLUG OF 9 PIN?
    I EXPERIENCED IN YEAR 2000 SEAT TOLEDO NOT WORKED, BUT NOW EXPERIENCED IN AUDI A3 2006 I WORKED WELL.
    WHAT DO YOU THINK?
    THANK YOU
  12. #1452
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    I changed both my obd cables 9pin connector just to be sure
  13. #1453
    batandball's Avatar
    May 2011
    Go to maplins and buy a new 9 D Way plug
    If it works use it
    BatandBall
  14. #1454
    batandball's Avatar
    May 2011
    Quote Originally Posted by batandball View Post
    like this one
    If it works use it
    BatandBall
  15. #1455
    pierre renault
    Guest
    Good day. my plug is not connected to pin 9
    I think that is different from yours or have cut wires!
