Page 155 of 462 FirstFirst ... 55105145150151152153154155156157158159160165205255 ... LastLast
Results 2,311 to 2,325 of 6927
  1. #2311
    Sep 2013
    Your link no work, see below working one
    How to solve Digiprog III Blue/White Screen problem? :
  2. #2312
    skens's Avatar
    Mar 2010
    Zagreb,Croatia
    hi
    i try now,work perfekt!
    regards
    Please dear members push the button thanks and reputation button(stars)
    do you need help? fill it in !!!
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    ECU type and number:
    Memories :
    https://www.digital-kaos.co.uk/forum...63#post1660863
  3. #2313
    Newbie g-ziro's Avatar
    Jun 2009
    on the Earth
    Quote Originally Posted by skens View Post
    hi
    page to help
    http://obd2repair.skyrock.com/314009...n-problem.html
    1 This might be solution to fix blue screen on digiwigi
    Unsolder U16 and U17 from the board, and solder CY7C1049D onto the board at the same place.
    regards
    1- Thanks
    2- link not function
    3- I have test this method, nothing changed
    An other idea .....
    Sent from my iPhone using Tapatalk - now Free
  4. #2314
    Moderator
    PremierD's Avatar
    Jun 2009
    Is it A Blue/white screen when you plug ino a vehicle ? or only when powering on the bench ?
  5. #2315
    Jun 2009
    on the Earth
    Quote Originally Posted by PremierD View Post
    If i power on its show me bluescreen. Nothing is change with changing chip.
  6. #2316
    Moderator
    PremierD's Avatar
    Jun 2009
    I meant mate .. are you using the 12volt supply ? or plugging it into a vehicle ?
  7. #2317
    skens's Avatar
    Mar 2010
    Zagreb,Croatia
    hi
    MERCEDES - W203 (C) - DIAG -7_01 with ST60
    1 Remove the tacho from the car
    2 used ST60 as a PDF MERCEDES - W203 (C) - DIAG -7_01 , DP3 it says 49
    3 adjust connector or download wrapper and connect
    4 panel lights up
    5 used menu w203 -7/2001
    6 does not read original miles
    7 Enter the desired km, work 15 min
    8 back in the car, you do not need to work and box"EZS"
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    Memories :
  8. #2318
    Jul 2013
    Scotland/Poland
    Hi somebady try Vw Crafter 2011? is chance to make ezs via DP3? Thanks in advance
  9. #2319
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by Radley View Post
    I'd use a blocker personally
  10. #2320
    teerak2uk's Avatar
    Apr 2009
    East Anglia
  11. #2321
    May 2010
    Quote Originally Posted by teerak2uk View Post
    and witch blokker is that?
  12. #2322
    carbandit's Avatar
    Dec 2008
    bonnie scotland
    blocker for a 9s12 ??? why when you can read and write with r260 /smok jtaq etc ... nec mcu is for blocker not motorola unless cas 4 secured
    anyway regarding crafter you will need to do ezs with r260 or smok .. .but tacho can be done by diggiwiggi
  13. The Following 2 Users Say Thank You to carbandit For This Useful Post:
    blackpirate (25th September, 2013), Radley (25th September, 2013)
  14. #2323
    it possible to copy eeprom bin from clone v4.82 to pc ? i tried to connect but without any sucess :/ Pc cant see digiprog ... any solutions?
  15. #2324
    Sep 2009
    avignon.france
    hello mates
    somebady try new clio 4 ??
    thx u
  16. #2325
    Sep 2009
    avignon.france
    hello mates
    thx u
