Page 247 of 462 FirstFirst ... 147197237242243244245246247248249250251252257297347 ... LastLast
Results 3,691 to 3,705 of 6927
  1. #3691
    Jun 2014
    Is there a way to make it work?
    Or do you guys have a suggestion for an order method?
  2. #3692
    captain crackers's Avatar
    Jun 2010
    england
    You will not harm the car trying it as anything VAG ie. Seat, Skoda, Audi or VW but it might be that nothing on the Digi 4.88 will do it.
  3. #3693
    Sep 2009
    Quote Originally Posted by everingo View Post
    Try the vw golf 6 2012 up menu it will work
    Don't forget to hit thanks button
  4. The Following User Says Thank You to javyb For This Useful Post:
    everingo (25th June, 2014)
  5. #3694
    Dec 2010
    Quote Originally Posted by captain crackers View Post
    Possibly you are asking a lot from a 200 Euro machine! Arthur.
    You right 100%
  6. #3695
    Jun 2014
    Double post
  7. #3696
    Jun 2014
    Quote Originally Posted by javyb View Post
    Thanks for your reply, it only didn't work.
    When i turn on the contact And choose the option you mentioned, the Car gives a reaction, but nothing more than a reboot And a reset of the time and service interval km.
    It is a start i think...
  8. #3697
    wiseman's Avatar
    Feb 2010
    Actually you can damage the flash on Johnson controls dashboard on a new polo, if you try change km it will say error on dash
  9. The Following User Says Thank You to wiseman For This Useful Post:
  10. #3698
    Jun 2014
    Double post
  11. #3699
    Jun 2014
    Quote Originally Posted by wiseman View Post
    What would you advice me to do?
    Maybe it's because i'm a noob, but a polo shouldn't be that difficult to handle, right?
    I mean it's not a BMW or mercedes that all the info is also stored on the car-key What makes it more difficult...
  12. #3700
    wiseman's Avatar
    Feb 2010
    Default Digiprog 3 clone questions and answers
    I mean it's not a BMW or mercedes that all the info is also storen on the car-key...
    Mate when It says unknown version the tool has not got the capabilities to change the km for that sw version because it doesn't recognize it. Yes trying another login like golf etc... Might work but JC DASH is only in polo not golf etc might be a VDO dash tho
    You want it to change use a different tool. Eg VAG PROG
  13. The Following User Says Thank You to wiseman For This Useful Post:
  14. #3701
    Jun 2014
    Thanks for your information, i appreciate the explanation.
    Probably this isn't the right topic for My next question:
    Is, beside the device What you just mentioned, the digimaster basic/digi-consulate a good alternative?
  15. #3702
    einet's Avatar
    Dec 2009
    put the dash out and make per hand.
    Not all can make over OBD, are this the first job by digi?
  16. #3703
    Jun 2014
    Yes, it is My first job.
    I know from a buddy me, that it is possible to adjust the polo by OBD(he has also a polo).
    And to remove the dash is a lot of work..
  17. #3704
    Aug 2012
    Xcan clone is best for vag (i also made a skoda octavia 2013 with it)-> never killed an dashboard with it
  18. The Following User Says Thank You to theghost For This Useful Post:
  19. #3705
    einet's Avatar
    Dec 2009
    when this polo is Johnson.
    2 Srews on the top
    2 srews on the side
    2 srews on the button from dash
    Put it out
    Conect UPA or xprog and read eeprom from mcu.
    use nyo then is all ok
