Page 266 of 462 FirstFirst ... 166216256261262263264265266267268269270271276316366 ... LastLast
Results 3,976 to 3,990 of 6927
  1. #3976
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by justy22 View Post
    Can digiprog 3 clone do cas 2 and 3 via plug
    Yes it can do some
  2. #3977
    Nov 2012
    Croatia
    Quote Originally Posted by Cardiag.ru View Post
    You foreget tell who make it works
    Any Digi clone can start work with HC08 and HC05 and ST53 dongle after modification. If you can use solder pen, you can make it itself.
    Problem is only shipment time from me to you.
    what modifications,original digi not work HC08 W203 EZS,some work and some not,what with baned device,
  3. #3978
    Nov 2012
    Croatia
    If device is baned must i buy new one?
  4. #3979
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by ikara View Post
    Yes if you want it updated
  5. #3980
    Dec 2009
    Prussia
    Thankyou for update.
    Please help stamp out this disgusting trade.
    JUST SIGN THE PETITION .....PLEASE
    https://savedogs.soidog.org
  6. #3981
    Moderator
    PremierD's Avatar
    Jun 2009
    Two updates ... or a double post Eric ?
  7. #3982
    Junior Member Kykv's Avatar
    Jan 2014
    Can someone PM me where to buy DP3 with SN able for updates. Thanks
  8. #3983
    Dec 2009
    Prussia
    Quote Originally Posted by PremierD View Post
    Owld age,Owld age................
  9. #3984
    honingkoning's Avatar
    Jun 2010
    Dessert
    Quote Originally Posted by Terios View Post
    hallo fellaz
    i get today a E36 2005 tryed with a YH 4.88 with st 16 cas 3 diag he gives SW and HW number after a while he gives unknown version i have been told it works starting with 2006 models . is it correct ?
    Thnx every info is welkom !!
    I would say 2005 is still cas 2.
    Did you remove cas?
  10. #3985
    Nov 2012
    Croatia
    Quote Originally Posted by gwee View Post
    all Yanhua Digiprog3 can be updated
    My is YH but baned sn as Cardiag said,how update this sn
  11. #3986
    Moderator
    PremierD's Avatar
    Jun 2009
    And where pray tell me did you get your last update ?
  12. #3987
    Nov 2012
    Croatia
    I bought it with 4.82 and update to 4.88,update get from here if i remember corect
  13. #3988
    Moderator
    PremierD's Avatar
    Jun 2009
    Then that is your problem .. .. someone has bought an update .. and then posted it here your serial matched so you used it .. now if you get your's updated to 4.92 .. I assume that you may then post that file .. for someone else with the same serial to get ... Just a wild guess here but I would say that's why some numbers are banned
  14. #3989
    Nov 2012
    Croatia
    i understand all what you say,but is possible update my device or not,in one post i read "baned not possible",other post "all YH can be update",what is the true
  15. #3990
    Moderator
    PremierD's Avatar
    Jun 2009
    Well mate .. Its not I who is updating them .. so I don't really know .. (just use some common sense )
