Page 343 of 462 FirstFirst ... 243293333338339340341342343344345346347348353393443 ... LastLast
Results 5,131 to 5,145 of 6927
  1. #5131
    Jan 2010
    Really? What modifications would that be teerak2uk?
  2. #5132
    Top Poster viliukas's Avatar
    Dec 2010
    Hi friends, i tried change mileage on mercedes w211, 2007 years (facelift), i choose on digiprog mercedes-w211-tacho diag-plug 16(60)-ok and in the right corner it write that - connection500 - verify 83 and it stopped to work and i got ''ERROR NO COMUNNICATION''. I tried a few times but all the time i got the same...The dash is VDO. With car everything ok - i tried connect with autocom diagnostic tool to dash and other blocks - everything works fine. Where could be a problem? Digiprog 4.94, can works fine on that device(i did a lot can bus VAG cars...). Thanks for your help.
  3. #5133
    Nov 2009
    Poland
    Try engine running
  4. #5134
    Dec 2010
    Quote Originally Posted by bodzio012 View Post
    Try engine running
    The car was standing about a month, i think starter motor cranked a little bit too slow because battery wasn't fully charged. You think low voltage could be a problem when digiprog try to read the dash?
  5. #5135
    Feb 2015
    Lincolnshire
    Jump start the car. Run for 2 miles. Turn car off. Ignition on and it should work
    Stop getting worried about what could go wrong, and start getting excited about would could go right!
    hmmmmmmm........eeprom
    Digi v4.94, Xtool, R260, R270, Smok, VagProg DataSmart 3+ Smelecom, Autel Maxisys ms908, SpeedFilters
  6. #5136
    Sep 2009
    Quote Originally Posted by viliukas View Post
    Take dash out and use st60
    Don't forget to hit thanks button
  7. #5137
    Dec 2010
    Quote Originally Posted by javyb View Post
    i could try, but the problem is that i have not a full digiprog ( without cable set). Maybe someone could help me with st60 cable pinout? It was a problem for you with this w211 that it couldn't be done throuhgt OBD and helped jus st60 cable for you? I have a friend who has digiprog 4.94 and done this model through OBD over 10 cars...thanks.
  8. #5138
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    ST 60
    ~db25 ~ dash
    ~13 ~~~ ~1 ~GND
    ~12 ~~~~ 4+6 ~POWER
    ~9 ~~~~~ 17 ~CAN
    ~10 ~~~~ 18 ~CAN
  9. #5139
    Dec 2010
    Quote Originally Posted by teerak2uk View Post
    ST 60
    ~db25 ~ dash
    ~13 ~~~ ~1 ~GND
    ~12 ~~~~ 4+6 ~POWER
    ~9 ~~~~~ 17 ~CAN
    ~10 ~~~~ 18 ~CAN
    Thanks mate I'll do this cable and i'll try to do this dash on the table. I have the last question: when i'll do this dash through OBD or on the bench digiprog should show me the old mileage value? Or it will be ''the old value: ?''. thanks.
  10. #5140
    Oct 2015
    Unhappy problem digi v4.94 from zoliobd
    Quote Originally Posted by Dayo View Post
    Unsolder the chip and try
    Hello I try to unsold chip but read wrong mileage and when I push "X" it says unknow version, my digi not work ?IMG_20151026_113420[1].jpgIMG_20151026_113454[1].jpgIMG_20151026_113501[1].jpg
  11. #5141
    aem's Avatar
    Jun 2014
    snowboarding on the mountain
    are you sure you put pin 1 where it have to be?
    FILE SERVICE
    REMAP+ dpf-egr-vsa-scr-lambda...cars/buses/agriculture
    Genuine WinOLS user
  12. The Following User Says Thank You to aem For This Useful Post:
    memet99600 (28th October, 2015)
  13. #5142
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Chip looks rotated but could just be poor picture
  14. The Following User Says Thank You to teerak2uk For This Useful Post:
  15. #5143
    aem's Avatar
    Jun 2014
    anyway that 35080 can not be write with digi.....only if is new 35080
    FILE SERVICE
    Genuine WinOLS user
  16. The Following User Says Thank You to aem For This Useful Post:
  17. #5144
    Moderator
    PremierD's Avatar
    Jun 2009
    ......... 35080 in a Merc e class mate ... you need to leave of the weed
  18. The Following 3 Users Say Thank You to PremierD For This Useful Post:
    DashProg (26th October, 2015), Dayo (26th October, 2015), javyb (26th October, 2015)
  19. #5145
    Sep 2009
    Quote Originally Posted by PremierD View Post
    There on about a astra h Tam
  20. The Following User Says Thank You to javyb For This Useful Post:
