Page 407 of 462 FirstFirst ... 307357397402403404405406407408409410411412417457 ... LastLast
Results 6,091 to 6,105 of 6927
  1. #6091
    Jan 2017
    This were my first steps. Sometime if you are new to a business and don't understand some search results, you want some different answers because you wanna learn as fast as you can. But everybody is different. You get smarter by more experience.
  2. #6092
    honingkoning's Avatar
    Jun 2010
    Dessert
    Quote Originally Posted by zix1 View Post
    yes but it was my fault because I was confused about the procedure. Since I ve done some BMWs now, I understand a little bit more about the work.
    Don't be mad, everybody speaks and understands English in a different way. We aren't all native english people. So sorry mate.
    No problem mate, you can do this car by dashplug it Will block synch between ezs and dash.
    Old milleage Will be traceable But not your problem.
    Wbr
  3. #6093
    Jan 2017
    Dash should be possible with DP3 I think.
    Ezs with r260? Or did someone also do ezs with DP3?
  4. #6094
    Jun 2010
    Dessert
    There is a difference between dp3 and digiprog, what tool are u talking about.
    You say dash is good enough, just do dash and forget about ezs.
  5. #6095
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by honingkoning View Post
    He's talking about digiprog mate
  6. #6096
    Jan 2017
    Default Digiprog 3 clone questions and answers
    Yes Digiprog 3 clone
  7. #6097
    Sep 2015
    northern ireland
    Quote Originally Posted by niallr View Post
    Hi. .. my digi 4.94 has started messing about.. first problem was 2009 b8 a4. Doesn't read old km and doesn't change km but still asks to check written value. (Worked on a b8 in the past) other car was 2004 told didn't read old value (?) And again didn't write new value.. select a golf of the same year and didn't read old value (? Again ) but did write new value. Then today I tried 2003 bora and doesn't read old value and when writing is says something like read backwards from 0fff 0x0. And doesn't write... have had this tool over a year and worked perfectly on 100s of cars reading old and writing new without problems. Anyone had the same problem? Maybe soldering or bad chip? Always been stored in a shock proof case.
    Sent from my SM-G900F using Tapatalk
    Anyone had this problem? My pcb is green so I reckon it's of poor quality
  8. #6098
    antenor's Avatar
    Jun 2010
    Here
    Fiat Doblo 2017 --- OBD OK
    If i help, d'not forget to press thank button!!
  9. #6099
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Quote Originally Posted by antenor View Post
    this is very strange..
  10. #6100
    antenor's Avatar
    Jun 2010
    Here
    Quote Originally Posted by Nicolas9 View Post
    Wy do you say that?
    MY DIGI 4.94 Clone can do it by OBD
  11. #6101
    Nov 2015
    Hi Guys!
    Can anybody send me a dump for GAL22v10d of Digiprog 3 - clone version?? - Please Send me! - I thing i have a "light" dump in my Gal22v10d of digiprog, because not working in can bus, and i changed already all another ic, or realey. And my odb cable new too. And i think, if i say for my seller, thath forexampl: the VW Golf5 - 2005 no connection, - - seller say: this is unsupported version!
    Please help me! Send me anybody a dump!
    Very Very Thank YOU!
  12. #6102
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Wy do you say that?
    did you make mileage higher or lower? (yes it makes difference)
  13. #6103
    May 2010
    or buy new one for 150 usd.
    2 a 3 car and you have your money back maybe.
  14. #6104
    Oct 2015
    Quote Originally Posted by Szinyo View Post
    Hi Guys!
    Hello friend, please use search function you will find the file in a thread.
    here is the link http://www.digital-kaos.co.uk/forums...87131-gal-dump
    If I help you don't forget thanks button
  15. The Following User Says Thank You to memet99600 For This Useful Post:
    Szinyo (12th April, 2017)
  16. #6105
    Mar 2016
    Hey m8s got a question. I got 07 chevy uplander. And it 4 pin connect 9s12. Tried to with digiprog 4.94 thru captivate is only 9s12 but fail to read or change. Anyone know how to do it.
