Ecusafe don't eliminates completely dpf on no kind of ecu.
But it works (i mean that you can remove physically dpf), and no mil light and no regenerations on some ecu, like edc16c39 (Fiat, Alfa, Lancia) and edc16 (Bmw).
Thanks for the reply,
ECU does not work then the other? type sims, edc 17 and the other.
Thanks for your response.
greetings
Nope... on other kind of ecus you have to put off manually dpf.
non program work on all ecu some you must do manualy on some you must put emuliator an so on...
sorry for my english
in particular, what should you do? Car that you have to do dpf off?
you should use a good tuner mate.. ecu safe is for those who want to get a quick profit dont bother answering calls from disapointed customers when things go wrong.
Just wait a few more months and general public will be aware that the ecu safe masks the problem, rather than switching the dpf off properly.
you wait when you get a car back with a running issue.. you spend a day faultfinding.. then you'll know how 'good' the ecu safe is..
I only care to know which ECU works,
Since I can not delete it manually.
Thank you all for your responses.
greetings
No problem mate. we are here to help whenever we can
