How to read the pin?
Is it possible if I post the dump from the immo to tell me the pin
http://www.dialab.ee/dejavu/Support/
Read login from the new used cluster and then use the instruction I posted in my earlier post.
Thanks!!!
I found vag EEPROM programmer 1.19 so I'm going to try hope is not get another dash with DEF.
Guys don't fight I have a car to play with it so I will let you know for everything what I'm doing on it
Not with RB4 dash.
I never was able to adopt it with 06 status.It will say every time "System not ready".
Soon as I set 04 , everything goes OK.Only way I can do it 06 mode if I write original CS direct to cluster .
As you know RB4 has 2 X VIN is dash and this may be a problem. I never was interested why, I just set 04 mode and adopt cluster.
So next week maybe I'm going to get the new used cluster so if it is impossible to adopted in mode6 how to set it in mode4?
Repair the DEF. Read login from ecu and dashboard and adapt it with the instruction I posted earlier. 100% success rate :-)
So I'm back. Today I've got the new used cluster so tomorrow going to try adopted in mode6 first then in mode4. I will let you know what is going on.
If I backup the dump from the immo 24c08 of the new cluster is it possible to restored after in case of DEF or another error?
