Results 1 to 13 of 13
    solitaire's Avatar
    LT, jonava
    Default SEAT Altea Hot start problem
    Hello, I have a Seat Altea 1.9d 2004,edc16 03G906016DG
    with a hot start problem, can someone help me please?
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    Have a nice day!
    solitaire's Avatar
    LT, jonava
    thank you very much!
    solitaire's Avatar
    LT, jonava
    hi bobolin4o,
    customer come back and complain that auto takes more fuel. I write back original damp, after month come back again and said that with fuel is normal.
    how to solve hot start and fuel problem?
    thangs.
    assitutto's Avatar
    May 2009
    Milano, Italy
    bobolin4o file is perfect
    he mod the correct map in correct way
    your client is crazy
    solitaire's Avatar
    LT, jonava
    Quote Originally Posted by assitutto View Post
    I made a few other cars by this file, no one has a problem, just this one.
    Jul 2011
    Flash the file again and see if your customer is happy with the second mod
    Sep 2012
    Hi I just saw the message. I wonder if the test ..
    Romania
    Quote Originally Posted by acpower View Post
    I do not understand - you fixed the problem or need to be fixed as the file uploaded in your post is a copy of the first request. The solution proposed before is good, and client should not have consumption problems - only if client had received opinion from friends that ecu modding ad this lower mpg problem, as I did. Here is another fix if necessary.
    warm start fix - 370803.rar
    bobolin4o's Avatar
    Quote Originally Posted by solitaire View Post
    hi bobolin4o,
    thangs.
    Hi!
    I'm sure, that in my dump no problem with consumption, only in cranking maybe...
    You have pleased to explain to the client...
    Lithuania
    Best way , to load same mod file and customer will be happy Thats tested 100 times
    solitaire's Avatar
    LT, jonava
    Quote Originally Posted by bobolin4o View Post
    Hi!
    ok. thangs.
  13. #13
    DK Veteran klakier's Avatar
    Lubacz?w/Poland
    hi bobolin4o,
    thangs.
    your file .... fixed
    GG: 7541425
    I'm not Sharing Passwords!
    If my post was helpful,
    press "THANKS" button!!!!
