And dump from AT88SC crypto eeprom? Do you have?
This is a chinese work not ours ! For that they are indebted
Carradio2001.
The new "toy" arrived. Soon starting tests !
Carradio2001.
I erased the flash content of ARM and I not have communication with MCU.
I have a few questions, from JTAG connector (20 pin) NRESET or NTRST will be used ? Inverted or not inverted ? VDD from JTAG connector must connect at +5v or at +3,3v ?
Some special options must select in H-JTAG SW or default ?
Any pins from interface blinking: TDO, TCK, TMS, TDI, NRST but no target find !
My Carprog is dead and must repair quickly. Any HELP will be apreciated !
Carradio2001.
Try this solution.
Pass - pmconnection_of_JTAG_Wiggler.rar
read me.rar
Look at this thread: http://www.digital-kaos.co.uk/forums...arprog-284274/
without passwords and other mystery![]()
BEFORE ANY REPROGRAMMING DESOLDER FROM BOARD AT88SC (8 PIN CRYPTO EEPROM AND DONT TRY TO READ OR WRITE!!!)
if this memory is already damaged solution will not work!
1.Use H-JTAG for programming AT91 with dump. H-Jtag schematic you will find in folder with H-Jtag software under Help pdf file!
First of all you have to erase ARM. Like shown on picture, if 1sec procedure doesnt work,leave it connected 2-3 minutes.
after that connect h-jtag programmer and programm processor with bin file
2.After successfull programming solder back at88 eeprom and run device
Do you flash your cp with success ?
i found this jtag schema based on 74125 .
ARM7 JTAG programmer
Power on the carprog interface, all PINs (TMS, RST, TCK, TDI, TDO) = 3,3V. Connect the JTAG Wriggler interface, the TDI =0,01V. When try to connect, "Unable to find the target" receive error. Try on desktop, laptop, with parallel cable, without parallel cable. The same and uncountered PROBLEM !
H E L P !
Carradio2001.
hi
in other forum i found this dump for carprog is not mine
I dont try if works
please send report
