Page 5 of 7 FirstFirst 1234567 LastLast
Results 61 to 75 of 93
  1. #61
    ahadi's Avatar
    Quote Originally Posted by carradio2001 View Post
    SOLVED, the CARPROG interface is alive
    Carradio2001.
    hello .
    how do you erase mcu by pin 55 to 3.3 v or by software .
  2. #62
    badenaleks's Avatar
    Feb 2012
    Windy City
    Maybe our friend Carradio2001 tell us step by step how to perform all.step by step. What will all be very grateful!
  3. #63
    badenaleks's Avatar
    Feb 2012
    Windy City
    Carradio2001 You are connected in this way?
  4. #64
    carradio2001's Avatar
    France
    The ERASE procedure is HARDWARE, connect pin55 to Vdd.
    The connection from Carprog to JTAG is: TDI, TDO,TCK, TMS, NRST, Vdd.
    Carradio2001.
  5. #65
    badenaleks's Avatar
    Feb 2012
    Windy City
    Lift the pin 55 and connected to vdd ?55 pin is all the programming mode is connected to vdd?
  6. #66
    badenaleks's Avatar
    Feb 2012
    Windy City
    When you've programmed you turn off power to the YUSB carprog ?
  7. #67
    badenaleks's Avatar
    Feb 2012
    Windy City
    I realized
    1.remove from the board eeprom
    2.put a jumper on the CPU pin 55 and pin 8
    3.The connection from Carprog to JTAG is: TDI, TDO,TCK, TMS, NRST, Vdd
    4.Using a program H-Jtag CPU rewrite
    5.put in place eeprom and enjoy.
    Correct way?
  8. #68
    Top Poster + andy99's Avatar
    EUROPA
    exactly this is correct
    Abritus AK400 BDM100 BMW-EXPLORER Beprog+ CLIP CarProg ETL ELM324 FVDI IDS J-Link GALLETTO3 SMOK K-SUITE Lexia3 MERCEDESINSTRUMENT MPPSv16 MVP ORANGE5 StarC4 TANGO UPA XprogM X-TOLL ZedBull
  9. #69
    Philippines
    Could i use this way to enable all sw on my original carprog?
  10. #70
    audiotek's Avatar
    May 2011
    The new "toy" arrived. Soon starting tests !
    Carradio2001.
    Hi, I bought the same jtag interface, could you tell me how to connect to carprog? It's this pinout correct?:
    Xprog Box Original, UPA Original, GromCalcTool,TL866A, Carprog, Renesas H8SX,Obdstar X300DP, EZ500, CHIPSOFT MID, Vagcom Original, Witech OEM, Ford VCM II OEM, Mazda VCM II, Volvo Vida-Dice, Hyundai & Kia GDS, MUT III, Ford & Mazda VCX, TS401, Cardaq-m, VAS5054 Plus, JLR , Cardaq 3 Plus, Launch x431 Pro3, Renault Can Clip, VVDI prog, Autel iM608, GM DPS, CDA6, Nissan Ners, Consult III Plus, Techstream, Honda HDS and iHDS, MMC flasher, Mazda MDS, Forscan, HP Tuner, Miniprog.....
  11. #71
    ahadi's Avatar
    i build a wiggler interface , the connection to arm mcu can be tested before erasing it.
  12. #72
    I do all this without success
    I program the AT91 but once you plug in the laptop The device does not work!!/usb device not found/
    Can anyone tell me what a mistake I do??
    I guess you do not do proper programming configuration
    desolder AT88
    do everything as explained and do not receive!!
    the problem is not in AT88
    After exchange with working carprog everything is fine
    error when programming AT91 and therefore ask for help
    Thank you in advance!!
    best regards
  13. #73
    France
    Quote Originally Posted by ahadi View Post
    NO, you can't ! The JTAG is not active, after erase the MCU, the JTAG become active.
    Carradio2001.
  14. #74
    programming is successful but became involved after the device laptop does not see it
  15. #75
    Apr 2012
    BG V.T.
    change at91sam7s256 !!!
