Page 3 of 7 FirstFirst 1234567 LastLast
Results 31 to 45 of 93
  1. #31
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Jul 2009
    Far far away
    And dump from AT88SC crypto eeprom? Do you have?
    4C7570755F73616E64755F696D6D6F5F736F6C7574696F6E73
  2. #32
    carradio2001's Avatar
    Nov 2009
    France
    This is a chinese work not ours ! For that they are indebted
    Carradio2001.
  3. #33
    Nov 2009
    France
    The new "toy" arrived. Soon starting tests !
    Carradio2001.
  4. #34
    Top Poster raptors's Avatar
    Sep 2009
    serbia
    Quote Originally Posted by carradio2001 View Post
    Carradio2001.
    I hope you make it, wait for the result.
    If the articles that you can use ic HC244 and HC245?
  5. #35
    Nov 2009
    France
    I erased the flash content of ARM and I not have communication with MCU .
    I have a few questions, from JTAG connector (20 pin) NRESET or NTRST will be used ? Inverted or not inverted ? VDD from JTAG connector must connect at +5v or at +3,3v ?
    Some special options must select in H-JTAG SW or default ?
    Any pins from interface blinking: TDO, TCK, TMS, TDI, NRST but no target find !
    My Carprog is dead and must repair quickly. Any HELP will be apreciated !
    Carradio2001.
  6. #36
    Sep 2009
    serbia
    Carradio2001.
    Try this solution.
    Pass - pmconnection_of_JTAG_Wiggler.rar
    read me.rar
  7. #37
    radsky's Avatar
    May 2012
    Earth
    Carradio2001.
    Look at this thread: http://www.digital-kaos.co.uk/forums...arprog-284274/
    without passwords and other mystery
  8. #38
    radsky's Avatar
    May 2012
    Earth
    Carradio2001.
    BEFORE ANY REPROGRAMMING DESOLDER FROM BOARD AT88SC (8 PIN CRYPTO EEPROM AND DONT TRY TO READ OR WRITE!!!)
    if this memory is already damaged solution will not work!
    1.Use H-JTAG for programming AT91 with dump. H-Jtag schematic you will find in folder with H-Jtag software under Help pdf file!
    First of all you have to erase ARM. Like shown on picture, if 1sec procedure doesnt work,leave it connected 2-3 minutes.
    after that connect h-jtag programmer and programm processor with bin file
    2.After successfull programming solder back at88 eeprom and run device
    Do you flash your cp with success ?
  9. #39
    May 2012
    Quote Originally Posted by raptors View Post
    This is a program that supposedly resets the counter, changing the serial number and creates a new PIN fail, but I have not tested. Avast virus we do not register, but you also scan.
    If someone has a good AT91SAM7s256 to fail, I would ask him to send me so I tried to clean up my carprog that slowly but surely count down counter.
    BEEPROG mcu for this but it will require an adapter for must be all legs in contact with the programmer.
    Have anybody dump for AT88SC25616C crypto memory ?
    It is necessary for this program...
  10. #40
    radsky's Avatar
    May 2012
    Earth
    Quote Originally Posted by AntonErmo View Post
    It is the most wanted eeprom dump in the world
  11. #41
    ahadi's Avatar
    Sep 2009
    i found this jtag schema based on 74125 .
    ARM7 JTAG programmer
  12. #42
    Nov 2009
    France
    Power on the carprog interface, all PINs (TMS, RST, TCK, TDI, TDO) = 3,3V. Connect the JTAG Wriggler interface, the TDI =0,01V. When try to connect, "Unable to find the target" receive error. Try on desktop, laptop, with parallel cable, without parallel cable. The same and uncountered PROBLEM !
    H E L P !
    Carradio2001.
  13. #43
    May 2009
    hi
    in other forum i found this dump for carprog is not mine
    I dont try if works
    please send report
  14. #44
    ALEXEI's Avatar
    Apr 2010
    H E L P !
    Carradio2001.
    power interface with external power not usb.
    put max 5cm length wires for connection with pcb.
    power wiggler interface with 3.3v
    TAKE OUT crypto eeprom from pcb
    report result
  15. #45
    ALEXEI's Avatar
    Apr 2010
    Quote Originally Posted by morito View Post
    hi
    I dont try if works
    please send report
    same dump as posted before
