Copy that DLL to c:\fgtech
and try.
I have it in c:\FGTech folder and in c:\Windows, c:\Windows\system, c:\windows\system32... it works in Windows XP but in Win7 reports a problem. Maybe someone have different software version?
I think it is problem with my Windows 7 because I just tried it with another Windows 7 and it works...
I have the same problem on XP :"Cannot find 'FGT2XX.dll'. Please re-install this application".
Galletto few days I worked and not anymore.
I tried on another PC and it works.
I turned off Norton, and then uninstalled and still "Can not find 'FGT2XX.dll'. Please re-install this application"
What version of windows 7, if it is 64bit version that could be your problem
I used driver from genuine fgtech software setup, then with v50 china sw it works on winows 7 64bit
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
This happened after few times working with this software.
Doesn anyone know how to fix? Checked both computers with win7 same issue.
View image: Capture
TUNING FILE SERVICE SINCE 2008
The problem is that galletto has a licensing method that was not made for mass selling. you need constant contact with seller.
So it's normal that it stops working. There are 3 options: Buy original, buy from someone that knows how to handle it, or buy other kind of machine.
These would be my solutions.
BR
check if you are the Admin from that ! right klik and check ! maybe you are not the admin than it doesnt start !
I have selected run as admin option ofcourse it is not this that causes the crash.
