the Cli team are working on a panel as we speak, so should be able to change cams from their.
You can change the cams from your web Interface.
put the IP of the box into your web browser
username = root
password = ipbox
username = root
password = ipbox
Thank you aftermath i have seen that but i dont find the cams,i must put them with ftp?
How?
The cams are there on the web interface , just go to option cam setup, and you will see client and server, above server you will see mgcamd, click on it and a drop down menu will appear, you can now choose incubuscamd , then click on change cam.
Thats all you need to do to change it.
It wont be long before the Cli team will have a panel plugin so you will be able to change from that instead of the web interface.
Ok thank you i retry that.
I have reinstalled the last CLI and there is only mgcamd in client and newcs in server.
Have you installed it and found others cams?
Thank's
they are already in the image, no need to install them.
as i said you change them from the web interface.
They are there.
I am sorry but in webinterface there is only mgcamd as client end newcs as server no others emus i just try this afternoon.
where it says mgcamd as cliend, click on mgcamd/to right hand side should open a drop down menu
Yes that's what i done,but there is no other choice only mgcamd.
can you show a screen shot, as ive never come across this before.
