This is a link to a post from last year to fix red light! worth a try!hope this helps! sorry had to delete posted link!
ahhh big slap then
i think better to copy and paste as no links to other forums m8
I put it on the starview site and they claim it does'nt work!
better delete the link on first post as not allowed
was having the problem where just a red light was shown on the front pannel and none of the methods people sugested worked as if the box was dead , now its fixed and working great and this is what you will need and how to do it yourself if you are having the same problem ,
-rs232 lead
-Flash Wizard Pro 6.3
first install Flash Wizard Pro 6.3 (i know this program is for dreambox but trust me it works) on a computer with a rs232 port ,
next connect sv7 box to computer using rs232 lead
then power on your box so the red light shows
now start up Flash Wizard Pro on computer
click on configuration and utilities on left side
now click format CF in the utilities section
your sv7 box should now be powered up showing green lights
now power off box and disconnect rs232 lead and exit the program on your computer
your sv7 box should now work as it did before and you can install new firmware .
hope this helps
courtesy of tk and rodz1983 for posting
and pomster
need to try it to see.
sent you a pm
i have been trying this and it dont work
with what did you try it with out of curiosity what setup? just want to be 100% sure.
yes but are they using a usb adapter also?,or just the null modem cable from pc tower to box.
it just keeps saying connecting but dont work
well then you have a different problem,original post was for red light showing,if you see other things like message box is working,now what firmware have you on box?,does your network need a reboot?is the code entered to enable connection to lan?have you paid your subs?
ive got red an green lite on wen i try flash wizerd it just comes u cant conect to ip address ive even try a box that still works it wont connect to that 1 ether
i have read on other posts of older boxes having an older chip and cannot handle the new firmware,numbers 101 and 102 i think on white label,so maybe another non starview box then or sat.
