Results 1 to 9 of 9
    Jul 2012
    Default EEPROM ST95080 LOSES THE MEMORY!!!!!
    Hi guys
    I planned the eeprom ST95080 and the car worked
    After two or three ignited off the car the eeprom loses its memory and the engine stops working
    Why eeprom lose the clean dump?????????
    The legs F3 and F4 I have not quit, maybe to blame this??????
    Can anyone to help me?????
    Best Regards!
    Shmortz's Avatar
    in the middle of nowhere
    change it with new one
    Jul 2012
    Default PROBLEM EEPROM ST95080 LOSES THE MEMORY!!!!!
    Good morning my friends
    I write the eeprom ST95080 with a clean dump, and the car is running properly
    After 2-3 times ignited-Turn off the engine stops working
    I read the eeprom ST95080 and I see that has changed the dump
    I have programmed 2 times but the dump is changed after some hours of operation of the car
    What is the problem and changes the dump!!!!!!!!!!
    Anyone who knows anything to help me please!!!
    Best Regards!!!
    Simply, the problem is the BSI triggering your S2000 ECU to write back the lock code to eeprom while ignition off.
    Jun 2012
    La Coru?a - Spain
    Try writting clean dump again, then lift pin3 of the eeprom from the pcb and bridge it to pin4.
    Jul 2012
    I do not know whether to blame I have not cut the feet F3 and F4
    Maybe blame this?????????
    Best Regards!!!
    racin-snake's Avatar
    Jun 2009
    cut f3 f4 and test ?
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
    Jun 2012
    La Coru?a - Spain
    Lift pin3 and bridge to pin4 will write protect the eeprom, so no changes in dump anymore.
    Jul 2012
    Hi Frend
    Can you make a plan with interconnecting with UPA and EEPROM ???
    Best Regards
