Results 1 to 2 of 2
    d2mike's Avatar
    Europe
    Default Problem w/ RB8 dashboard: DIS, Odo and time field is not working
    Hi guys,
    I need your help with a RB8 Immo4 dashboard where the DIS, odo and time field is not working.
    I already replaced the 24c08 EEPROM and programmed it to the NEC mcu.
    When I start the output test with VCDS, DIS, odo and time field are working but when I stop that procedure all fields are getting black again. All other things are working and VCDS doesn't give me any errors.
    Regarding the housing it shall be a 8E0920931P and also what I can see in flash dump it's definitely from an Audi A4 B7.
    Do you have any ideas why these fields are not working? I already checked the wiring and tried different 24c08 eeproms .
    Thanks guys.
    Cheers, d2mike
    d2mike's Avatar
    Europe
    *push*
    Any ideas?
