Have few from Trafic and Vivaro 2.5CDTI 0281013363 but it have 3 different SW numbers like 1037xxxxxx in 3 plases in flash ( 10150h, 40010h, and 1c0010h).
Closest to your number is 388107, so if you need it just let me now.
i have this one but in 256K read by obd
i see it's an auto gearbox?
yes, it's an auto gearbox and I also do have some other files for this ecu, but then I get an eprom error, so Ineed the correct software version
Yes, I have full BDM with eeprom, but you will need to math it to IMMO for your car, or make it virgin.
Dump from is AT car, password send to PM
I have downloaded the file, but it seems to be damaged.
Can you try to upload again?
File is OK, just check it.
Use 7Zip and password in PM
I have been able to get rid off all errors, but the car is shifting gears differently, so it seems my only option is to get the original software 388184.
post flash here from both ecus, and the ori flash you read by OBD
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
I have taken the car to the dealer and they reprogrammed the ecu and all is fine, so no need for the file anymore.
