Results 1 to 4 of 4
    omglol's Avatar
    Jan 2009
    Europe
    Default Vauxhall/Opel: SWCAN
    Hello!
    Does someone know on which controllers SWCAN (Single Wire CAN) is used? I diagnosed lots of these cars with OPCOM, but I've never seen it would switch to SWCAN, only high and medium speed CAN.
    Thanks for answers!
    Staffs UK
    example vectra c
    pin 1 diagnostic plug green wire
    to CIM X29/19
    X29/4 green wire to Airbag and selector lever module (auto only)
    XC29/20 green wire to IPC 5
    IPC 6 green wire to BCM XC31/41
    BCM XC31/40 green wire to INFO X19/28
    INFO X19/25 green wire to aircon and addon heater
    inter module connection bus
    tpms,uec.rec,ddm,pdm,srm, etc will also be on it...... anything NOT time critical
    I may be wrong but I think the immo data may be on this line ...uec rec ddm pdm ipc dis cim like a "w" line on a vw
    If you think about it how does a CAN based opel ecu report current CAN faults to your tool?
    omglol's Avatar
    Jan 2009
    Europe
    Hmm ... I diagnosed TPMS a few times on Vectra C ... but it was always on medium speed CAN (MS-CAN).
    Staffs UK
    you probably don't use it when there is a functioning CAN system.
    inter module connection bus...... not diagnostic bus
    maybe its like a w line on a vw? will work as a k line at a push if everything else is down.
