Results 1 to 7 of 7
    Nov 2008
    Question Cannot Get SuperTV2 Channels To Work ON Apple TV2
    I am a newbie to apple tv2 with the jailbreak and I can get most channels to work, but I cannot get any Super TV2 channels to work. It?s as though they are just loading up and getting ready to play, and then it stops. Is there a plug-in I need to download or update, I need your advice please.
    Aug 2012
    after I updte with editordreambox not see any program clones dm500s
    Mar 2011
    Scotland
    Quote Originally Posted by tinbin View Post
    I am a newbie to apple tv2 with the jailbreak and I can get most channels to work, but I cannot get any Super TV2 channels to work. It***8217;s as though they are just loading up and getting ready to play, and then it stops. Is there a plug-in I need to download or update, I need your advice please.
    Some of the plugins dont work well.
    Plugins i would suggest are
    TV Catchup - xbmc.org and xbmc.org
    Crackle2 - xbmc.org
    1channel - xbmchub.com
    Tube plus - xbmchub.com
    NaviX - xbmchub.com
    Project freeTV - xbmchub.com
    4oD - xbmc.org
    Demand5 - xbmc.org
    I would also install some of the repositories and other plugins available using fusion installer, most of the info needed for installing, using, maintaining these plugins / repositories can be found at both the sites mentioned.
    Mar 2011
    Scotland
    Personally i dont use the live tv plugins but i forgot to mention and im not 100% sure on this either but this could have something to do with the version of xbmc that your using some plugins work best with nightly builds and some plugins work better with the current stable release of xbmc eden 11.0, it could also have something to do with the rtmpdump / librtmp.dll files as im sure you need these to watch live tv streams.
    Nov 2008
    Thank you very much for the info m8,do you know if bbc iplayer works ok .
    Mar 2011
    Scotland
    I dont use the BBCi Player on the ATV2 but when i used it on the pc it worked fine, again you need to update the rtmpdump / librtmp.dll files for it to work properly as i'm sure it has something to do with DRM hence why it doesn't work without the needed files.
    Mar 2011
    Scotland
    The link for fusion installer and tutorial, this will allow you to install most of the video plugins found over at xbmchub from one place.
    Fusion: Easy Addon Installation for XBMC | XBMC HUB
    If you need to manually install repository and addon zip files then for ATV2 i use filezilla to ftp the files over to the ATV2 from the pc, you'll also need the IP address which can be found in Settings -> General -> About. on the ATV2.
    [ame=http://www.youtube.com/watch?v=rYGIjbR6Jn4&feature=player_embedded]Plugins Installation for XBMC on Jailbroken Apple TV 2 Step By Step - YouTube[/ame]
    Normally to log into the ATV2 the following is used in filezilla
    ATV2 IP address
    Username: root
    Password: alpine
    Port: 22
