Results 1 to 2 of 2
    Jun 2009
    Default skybox m3 multisat
    hey does anyone no how to set up multisat on this box its supposed to support it. i use a motorised setup.
    DK Veteran darcu5's Avatar
    Jun 2011
    Bolton, Lancs.
    If it's same set up as the s9 & s10 then you need to go to menu- sats set your motor to usals then select the sats again and tick whichever sat you want to use, then go to single sat scan and scan them, Only problem is you will have to delete some channels as you go along or you will fill up the 5000 channel limit in no time.
    If it isn't broke, don't try fixin it..!!!
