Results 1 to 8 of 8
    Moscow
    Default Speed limit Peugeot boxer 2008
    Hi.
    I have Peugeot Boxer 3.0 l. 2008 ECU BOSCH 0281014211, with speed limitation 90 km/h.
    Car has tachograph.
    Where there is a speed limiter information ? (in Flash or eprom)
    hello
    you can switch off limiter in flash!
    Moscow
    Who can help to delete speed limit in flash? Thanks in advance.
    Denmark
    test and report no pass needed
    Moscow
    The bus is still losing power after a set of 90 km / h.
    Jun 2012
    Romania
    Quote Originally Posted by Manmart View Post
    The speed limiter is set to 250 km/s in the turboracing's map - it was 160 km/h anyway - so your speed limiter is somewhere else.
    Hit the Thanks button if I helped you!
    Land of the Sun
    Here are limiting at 250 km/h
    pass in PM
    Back of a van
    Did anyone find out where the 2008 Boxer speed limiter is, ECU or BSI?
