Results 1 to 15 of 20
Hybrid View
    DK Veteran pspmixer's Avatar
    Jun 2009
    liverpool(UK)
    Default crossepg problem
    i have a problem with cross epg
    im not getting a full epg of what is on 28.2e im only getting now and next and thats only on some channels
    ive tried downloading and forcing it load but they dont seem to do anything
    set it up like this -
    enable cav import YES
    force epg reload YES
    show as plugin YES
    show forced plugin NO
    when do a restart enigma that scren goes green ( think its the crash screen) then trys to reboot its self but just hangs so i have to turn off at the back then back on to get it back to normal but after that epg doesnt show anything at all
    if anyone can help id be greatful
    p.s once i have this sorted would like to know how to set up epg to download by it self so i dont have to get it each week
    digicon's Avatar
    What image are you using on the Duo, and are you using OpenTV or Rytec server to download the 28.2? east EPG.
    Just to clarify and check i have just done a manual download from OpenTV which gets the EPG direct from the Satellite EPG Transponder and it has come back with a full 7 day guide so thats definitely working.
    Jun 2009
    liverpool(UK)
    using open pli never had a problem with it all plugins work fine on it just like any other image
    using rytec as it the only ones i can see that have 28.2 next it
    i set my friends duo up the same and isnt getting any problems with his epg
    V.I.P. Member dell_xps's Avatar
    Select open TV, make sure its checked, yellow button to download, turn to a radio station for a min or two, then back to channel you were watching, should be a full 7 day epg now, in Vix anyway m8 :-)
    digicon's Avatar
    OpenTV just to clarify does exactly the same in any image and not just Vix
    Jun 2009
    liverpool(UK)
    i have all 28.2 tick on xmltv providers tick
    same on open tv providers and xepgdb providers
    still doesnt come up with full epg
    i have a 120gb hard drive in and it is empty i also hav that select in config menu also tried internal flash too but still the same
    digicon's Avatar
    Quote Originally Posted by pspmixer View Post
    Ok first thing to do is to get the 28.2? EPG working so untick everything and just leave the 28.2? one ticked on the OpenTV providers.
    Then when you exit back to crossepg make sure the Reload on boot is ticked and also it maybe an idea that where ever you have the EPG being saved to either USB or Internal harddrive just delete the contents of the EPG folder.
    Try again
    Jun 2009
    liverpool(UK)
    Quote Originally Posted by cactikid View Post
    i wonder if you have 2 many selected and its getting overloaded with info,that happened me with the solo,i unclicked them and started again and now its loading,maybe a glitch in the lan as it took ages to load nothing
    on friends box i tick all of them and they fine on that boxjust not mine
    Try again
    tried doing it and they wouldnt untick so delete epg folder an download again only came up with one
    digicon's Avatar
    when you say it only came up with one what does 'one' mean exactly
    Sep 2008
    You should be getting this on yer box m8.
    Jun 2009
    liverpool(UK)
    i mean one epg info e.g sky sports news - first now (now) blank (next) sorry should of been more clear
    Quote Originally Posted by dell_xps View Post
    yeah ive got that mate i cant untick the others ones tho so i just have that ticked
  13. #13
    digicon's Avatar
    if you cannot untick the rytec and other providers then something is wrong, I only have 28.2? east opentv ticked on mine and it works everytime.
    I think you may need to do a re-flash of the image and start again.
  14. #14
    Sep 2008
    do you not just reclick it to add or remove the green tick.
  15. #15
    Jun 2009
    liverpool(UK)
    was think that but was trying to avoid that if possible
    yeah you either click ok or press green but when i untick them then go off the provider it somehow ticks its self again (know this as i went back into after i had untick and it was back ticked)
