Results 1 to 13 of 13
    Jun 2008
    Default dbox2 connection refused
    awrite guys i have a nokia dbo2 im trying to put new cams on but i cant conecct to it
    it has commando 10 on all i get is connection refused
    never had a problem with the last 1 been at it for hours
    Bulld0g's Avatar
    Apr 2008
    Liverpool
    Make sure password is "commando"
    V.I.P. Member gizmo.1484's Avatar
    Apr 2008
    WestYorkshire
    Have you turned off all firewalls?
    Have you set your network settings on your pc
    Eg
    pc:192.168.0.23
    Dbox: 192.168.0.24
    User name: root
    Password: commando
    Jun 2008
    aye i have done all that but just refuses
    Bulld0g's Avatar
    Apr 2008
    Liverpool
    As gizmo says set username and password as described. make sure firewalls are turned off and ip addresses are set correctly.
    The problem with commando images is usuallt people putting in root or dbox2 as password as opposed to COMMANDO. If the problem persists and you want a quick fix, then flash a new image using IFA. Well that's what i would do m8
    Apr 2008
    WestYorkshire
    Have you checked your network settings as if not set right then it will not connect.
    If thy are ok then reboot your box then try again make sure your xover cable is plugged in as sometimes the box does not see the cable if you plug it in when on.
    Jun 2008
    kk a will try them l8er
    Jan 2009
    Quote Originally Posted by Bulld0g View Post
    Thanks stuck trying to get in.
    Junior Member kelvie09's Avatar
    Jun 2009
    hartlepool
    try flahing lincsat 7.25 fullish from d/loads section mate with ifa then jst get service and bouquets for your area upload them onto box and every thing should work fine, all channels and every thing . i have nokia 2x and this is what i have just done and its working fine
    Aug 2009
    hi kelvie09 I am having the same problem have tried to flash image and getting nowhere will try what has ben said in here and come back you
  11. #11
    Aug 2009
    Default Can't Download
    I have registered confirmed my account and have posted to the forum but yet when i go in to download Commando 11 image it tells me i'm not allowed anyone know why?
  12. #12
    Bulld0g's Avatar
    Apr 2008
    Liverpool
    Quote Originally Posted by smartie View Post
    Takes about 15 mins maybe longer for the server to update.
  13. #13
    Aug 2009
    Default Vista Help
    Hi all - ihave downloaded commando 11 from the download area and am trying tp flash ot using a crossover cable (don't have a null modem connection on laptop) and FLA.
    I have got so far with it to the extent that the dbox will not boot anymore - and I dont see the "flashing" word when i try to flash it with the new image.......does anyone have any ideas.
    Is this a Vista problem or dbox problem - in the network part of Vista i see "unidentified network" is this the problem???
    Any help greatly appreciated.....
