Thread: Skybox M3
    Jun 2012
    Default Skybox M3
    Hi guys im after some help please with a problem im having with my box.
    I have an M3 set up and it seem ideal for what i need.
    I have scanned all the new channels in for sky etc and i have a provider in place for viewing them and i can view them.
    The problem is i have noticed for example $ky sports 1HD is coming up under multiple channels/frequencies. One channel is viewable for a while then it stops and i have to try one of the other $ky Sorts 1 HD that was found and then when i try that it can be Viewable.
    So my question is -
    IS the service my provider giving me causing the interruptions or do you think its the Skybox M3?
    phew sorry for going on a bit.
    cheers
    M
    Jul 2012
    Your provider is the problem,alternatively download deejays list from here and then you will only have one set of all and dead channels cut out all the work done for you,then you can see for sure it's your provider then you can get on to him as you have made sure it's not your end
    Even try a test line and run that instead of you provider for 24 hour then you know it's not you
    Good luck
    Jun 2012
    i will download that channel list then give it a try tonight.
    cheers
    Aug 2012
    UK
    Are you connected via wifi or Ethernet ?
    Make sure none else in the house is downloading too much and using bandwith up, this can cause your provider signal to drop
    hope this helps
    Andy
    Jun 2012
    i have updated the channel list and still get the same problem so it must be the provider. doh!
    Jul 2012
    Default Pm
    You've got a pm pal
