Results 1 to 10 of 10
    Dec 2010
    Default ews 3 big problem
    I tried to read ews 3 with x prog and was read all FF, please I need help car came to me working. Help me syncronize the ews again. thanks
    Mar 2011
    Which car bmw?
    Fec001's Avatar
    did you connect MODB pin?
    Dec 2010
    Yes, I conected everything ok.
    Car is BMW 525 tds
    furnata's Avatar
    Bulgaria
    Or remove immo -Otocheck have working solution for 1373 ecu
    Im here to help and to be helped
    obdmaster's Avatar
    Never never land
    Thumbs up
    Quote Originally Posted by jacostanzo View Post
    I take it maskset of hc11ea9 was 2D47J and you tried to read using xprog by k line????
    Some 2D47J MCU,s are secured, and if you try to read by k line erases memory.
    Best to order new ews (around 100euro) from dealers and synch. All old original keys will work.
    You need every tool in the book, to do this auto locksmith job.
    richard27's Avatar
    Aug 2011
    If you 0d46j ews3 ??
    ​information sharing
    bram380's Avatar
    Indonesia +628153111774
    Dont read by K-line for EWS3 with mcu 2D47J.
    All data will be erased.
    Read/write on borad methode.
    If you can read flash DME & post here.
    i will give the ews3 data & match with dme.
    then resync with gt1.
    No need buy new ews from delear.
    Please detail ewse type?
    Dec 2010
    I read by k line, mcu is 2d47j.
    ECU is bosch 0 281 001 373
    I sent the ECU and EWS to a friend mine, he will try to sync, if he couldn't sync I will post ECU dump here. Thanks mates
    Bram,
    Can you help me with same problem?
    I attach original DME Flash from ECU 5WK9 0322index 10. DME MS41.0.
    I have used EWS3 I can program if you can give me file. The original is EWS3 0d46j (erased), HW1 SW05.
    I very much appreciate your help.
    Regards,
    M.
