Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
  1. #16
    gelencserg's Avatar
    Garage
  2. #17
    Liteace's Avatar
    Mar 2009
    On a rock
    Quote Originally Posted by morfej View Post
    Nemo/beeper:
    1 Line CAN DIAG High
    2 Channel not connected
    3 Channel not connected
    4 Body earth
    5 Electronic earth
    6 Line CAN IS High ISO bus
    7 Channel not connected
    8 Channel not connected
    9 Line CAN DIAG Low
    10 Channel not connected
    11 Channel not connected
    12 Channel not connected
    13 Channel not connected
    14 Line CAN IS Low ISO bus
    15 Channel not connected
    16 Permanent +
    Ive got a 2014 Beeper that I need to coms with airbag, this is the pinout at DLC?
  3. #18
    morfej's Avatar
    Quote Originally Posted by Liteace View Post
    Exactly ... at DLC (OBD)
  4. #19
    Jul 2021
    GLOBAL
    Problem solved?
  5. #20
    Bllinda's Avatar
    Baltic
    I guess S.1279 do nothing more than rerouting pins.
    If you check the standard Euro 5 pinout:
    Pin Description
    1 Ignition positive
    3 Line CAN DIAG High
    4 Body earth
    5 Electronic earth
    7 Line K diagnosis (Engine management - Automatic gearbox - Additional heating)
    8 Line CAN DIAG Low
    9 Channel not connected
    12 Line K4 diagnosis (Stability control - Hydraulic suspension)
    13 Line K diagnosis - BCM
    16 Permanent
    and Jumper III:
    1 Line K diagnosis (Stability control)
    4 Body earth
    5 Electronic earth
    7 Line K diagnosis (Engine management)
    9 Line K diagnosis (Tachometer)
    12 Line K diagnosis (Additional heating - Power steering)
    16 Permanent +
    test if you adapter does the rerouting as described above.
    Nemo/beeper:
    4 Body earth
    5 Electronic earth
    9 Line CAN DIAG Low
    16 Permanent +
    * OBDII Euro 5 pinout Jumper III Nemo Beeper
    1. Ignition positive Line K diagnosis Line CAN DIAG High
    2. - - -
    3. Line CAN DIAG High - -
    4. Body earth Body earth Body earth
    5. Electronic earth Electronic earth Electronic earth
    6. Line CAN IS High ISO bus Line CAN IS High ISO bus Line CAN IS High ISO bus
    7. Line K diagnosis Line K diagnosis -
    8. Line CAN DIAG Low
    9. - Line K diagnosis (Tacho) Line CAN DIAG Low
    10 - - -
    11 - - -
    12 Line K4 diagnosis Line K diagnosis -
    13 Line K diagnosis - BCM - -
    14 Line CAN IS Low ISO bus Line CAN IS Low ISO bus Line CAN IS Low ISO bus
    15 - - -
    16 Permanent + Permanent + Permanent +
    today
    A topic that interests me
