this cars : boxer III - bipper - boxer III minibus
jumper III - nemo - jumper III minibus
you need adapter for scan all system
adapter ref : S.1279 - 9780.x4
d'ont foget THANKS
d'ont foget THANKS
exactly
XS EVOLUTION+s-1279
must swich the bouton to position -A-
I guess S.1279 do nothing more than rerouting pins.
If you check the standard Euro 5 pinout:
Pin Description
1 Ignition positive
2 Channel not connected
3 Line CAN DIAG High
4 Body earth
5 Electronic earth
6 Line CAN IS High ISO bus
7 Line K diagnosis (Engine management - Automatic gearbox - Additional heating)
8 Line CAN DIAG Low
9 Channel not connected
10 Channel not connected
11 Channel not connected
12 Line K4 diagnosis (Stability control - Hydraulic suspension)
13 Line K diagnosis - BCM
14 Line CAN IS Low ISO bus
15 Channel not connected
16 Permanent
and Jumper III:
1 Line K diagnosis (Stability control)
3 Channel not connected
4 Body earth
5 Electronic earth
7 Line K diagnosis (Engine management)
8 Channel not connected
9 Line K diagnosis (Tachometer)
12 Line K diagnosis (Additional heating - Power steering)
13 Channel not connected
16 Permanent +
test if you adapter does the rerouting as described above.
1) As I remeber there was no IC inside... will open it today again
2) Because jumper/boxer and nemo/bipper have different pinouts on obd2 connector
3) I can stop attaching files.... that's an option.
Nemo/beeper:
1 Line CAN DIAG High
4 Body earth
5 Electronic earth
7 Channel not connected
9 Line CAN DIAG Low
12 Channel not connected
16 Permanent +
Liteace (18th January, 2021)
