Hello ,
I try to use 2 cable vag k can commander 1.4 but they doesn't work(i always have message target not responding..)
Is it a solution to repair this cable pls
Hello ,
Try to switch the anti virus off.
i usually leave it on COM 10. go to device manager on the pc, select the cable advanced property and choose same Com as vag software
Hello all
Very thanks for all your fastest answer !
no antivirus in this computer.
I have downloaded vag can commander pack and when i flash "ept" file sometime my cable reconized my car but only on kline (only sometime , maybe is because my chinese cable?)
Maybe your cable kkl,and never will make conection on can cars),Open your cable and look inside if have can
If u have the answer say Thank You!!
what car is it? i got china one too and works great.
1. disable antivirust
2. change com port (1, 2, 3, or 4) in device manager
3. change com port in .ini file
and it must works. It's k-line and can connection interface.
Or ... maybe there is a hardware problem ....
Hello all !
No antivirus on my computer , port com select is com2
K-line work on 1 car of 3
Can never works on my 2 cables
So k-line work on my seat leon but doesn't work on vw polo tdi year 2002 and doesn't work on audi a3 tdi 130 2002
For Audi a3 i try to select magnetti marelli read direct and it read and i can save a file but i think bad filecan anyone tell me if this dump is good or not
Can vag k commander 1.4 work with audi a3 ? what must i select (magnetto shadow1 or direct read?)
Very very thanks for all your help![]()
