Results 1 to 10 of 10
    Aug 2012
    Default help for vag k can commander
    Hello ,
    I try to use 2 cable vag k can commander 1.4 but they doesn't work (i always have message target not responding..)
    Is it a solution to repair this cable pls
    Regards
    leandroks's Avatar
    Feb 2010
    Brazil
    Try to switch the anti virus off.
    blackpirate's Avatar
    Jun 2009
    Quote Originally Posted by leandroks View Post
    if he get this msg mean that main exe passed AV!:P
    so thats not the pb!
    see what com port its uses and put same number in that .ini file
    cheers
    If freedom is outlawed, only outlaws will have freedom!!!!
    Meat-Head's Avatar
    Quote Originally Posted by blackpirate View Post
    cheers
    Second that, discovered that last week.
    Feb 2010
    i usually leave it on COM 10. go to device manager on the pc, select the cable advanced property and choose same Com as vag software
    Aug 2012
    Hello all
    Very thanks for all your fastest answer !
    no antivirus in this computer.
    I have downloaded vag can commander pack and when i flash "ept" file sometime my cable reconized my car but only on kline (only sometime , maybe is because my chinese cable?)
    Regards
    ovi_dk's Avatar
    Jul 2010
    On board
    Maybe your cable kkl,and never will make conection on can cars),Open your cable and look inside if have can
    Regards
    If u have the answer say Thank You!!
    Feb 2010
    what car is it? i got china one too and works great.
    Sep 2009
    Poland
    1. disable antivirust
    2. change com port (1, 2, 3, or 4) in device manager
    3. change com port in .ini file
    and it must works. It's k-line and can connection interface.
    Or ... maybe there is a hardware problem ....
    Aug 2012
    Hello all !
    No antivirus on my computer , port com select is com2
    K-line work on 1 car of 3
    Can never works on my 2 cables
    So k-line work on my seat leon but doesn't work on vw polo tdi year 2002 and doesn't work on audi a3 tdi 130 2002
    For Audi a3 i try to select magnetti marelli read direct and it read and i can save a file but i think bad file can anyone tell me if this dump is good or not
    Can vag k commander 1.4 work with audi a3 ? what must i select (magnetto shadow1 or direct read?)
    Very very thanks for all your help
