It will start regeneration and limp mode after some time
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
newbie question but how can start renegeration if the filter is phisically removed and there will be no differential between the two sensor?
Ecusafe trys to hide the dpf, the function is still turned on, ecu will see no pressure and know filter missing, after comes limpmode and random regeneration to try and finish the regen cycle
Yes, Ecusafe 2 not work and you need from manualy solution.
Best regards.
All full worked manual solutions - FAP/DPF OFF, Adblue/SCR OFF, EGR OFF, TVA OFF, SWIRL OFF, O2/Lambda OFF, DTC OFF and etc
Our database available for download 24/7 on EVC server for all legal WinOLS users
Manually by 2 switch solution?
u will never find the switch mate, why play with peoples cars?
contact a professional and get it sorted properly
spend money to make money
try ecutuners
"I always tell the truth. Even when I lie"
"We Taking Over, One City At A Time"
