Drc compact (16th May, 2015)
This program corrects the checksum?
A greetings
I read the e2prom (95160) Peugeot 307 1.6 HDI 2005 with BDM100, this generates a file of 8k, I saw the WinOLS, it seems that multiplies x 4 data, there are 4 identical blocks.
If I change EEPROM data for immo off in the 4 blocks, I have to correct the checksum or not needed?
I can not write file 2k with BDM100, generates error wrong size.
Thanks.
no, you don't need correct the CHK. Only modify immo off data in all 4 blocks (all 4 blocks must be identical) and write it with BDM.
artur12 (10th February, 2018), Drc compact (16th May, 2015)
Pali33 (16th May, 2015), parrot1964 (24th November, 2015)
this software its ok
Well done I'll try this. thanks!
WITH EDC16C34 1.4HDI ?
nice...
The difference between men and boyz...Is the price of there Toyz.
LEACHERS.....DONT KEEP ASKING FOR PASSWORDS
DONT FORGET TO PRESS THE THANK YOU BUTTON IF MY WORK HELPED YOU....
bouchmid (23rd February, 2017), reglissebudy (16th October, 2018)
HI
Good work guys.
thank u very very mush
aldriana (20th August, 2016)
thank you sir
Hi how to dowload the soft please sorry for my bad english
This looks like what I need. So I only need to read ecu epprom on bench run threw software and car should start? No need to do mod with bsi epprom?
Thanks all with experience
Genuine tools including Abritus, Autotuner Master, Bosch Ford vcm2, smok UCDS FULL JTAG FULL pcm flash, IO terminal, UPA, Autel maxicom pro, MTX dpf, dtc, immo edc17 UCDS, and a little well maintained hairy box from china I play inside!
4.94 x100 fgtech kess ktm ktag mpps skp. And still collecting
yes ... no need mod the bsi eeprom.
artur12 (10th February, 2018), norman1967 (20th July, 2017)
