Page 1 of 2 12 LastLast
Results 1 to 15 of 26
    Aug 2012
    Bulgaria
    Default Suzuki_alto_1998_immo_problem
    Hi, I have a problem with Suzuki Alto 1998 1.0 petrol with Mitsubishi ECU 33920-70f70 check engine flashes constantly and there is an error in a ecu from a "no communication with Immo" . All power supplies are tested for Immo and ecu, I think there is a lack of synchronization Immo - ecu. Attach the dump from the ECU and Immo x24c01 and also the code of the key tiris 4c. If anyone has any ideas please help. Cheers to all. Plamen.
    Aug 2012
    Bulgaria
    Nobody has seen this primate HA HA
    keysph's Avatar
    Feb 2011
    This is a Mitsubishi system.
    From what I see... the immo is locked
    "If the system is locked the engine warning lamp should flash an error code of 54. If this happens follow the following procedure:
    1. Perform a battery reset operation, procedure on the next page.
    2. Leave ignition on for 35 minutes.
    3. Without turning the key off, connect the tester.
    4. Check for fault codes and clear if any are found.
    5. Program key, at this stage ignore any error message if displayed.
    6. Check for fault codes and clear.
    7. Check key for operation.
    BATTERY RESET PROCEDURE
    Under certain circumstances it is possible for the immobilizer and engine control unit to become locked. This may present
    itself in a number of different ways. It can cause :-
    • Communication with the programmer to cease.
    • The vehicle may crank but not start.
    • The immobilizer warning light may be off or on all the time.
    • It may not be possible to program transponders/remotes.
    To overcome this follow the following procedure :-
    • Remove all battery chargers and jump packs.
    • Disconnect battery positive lead and negative lead.
    • Touch the positive and negative cables together for 10 seconds.
    • Reconnect the positive battery cable.
    • Reconnect the negative battery cable. "
    Nov 2009
    Chile
    Default alto
    [QUOTE=plamen 63;1669368]Hi, I have a problem with Suzuki Alto 1998 1.0 petrol with Mitsubishi ECU 33920-70f70 check engine flashes constantly and there is an error in a ecu from a "no communication with Immo" . All power supplies are tested for Immo and ecu, I think there is a lack of synchronization Immo - ecu. Attach the dump from the ECU and Immo x24c01 and also the code of the key tiris 4c. If anyone has any ideas please help. Cheers to all. Plamen.[/QUO
    try with new dump
  5. The Following User Says Thank You to LATTINO For This Useful Post:
    JAVBETT (27th August, 2022)
  6. #5
    Aug 2012
    Bulgaria
    Thanks for having responded. The first procedure has been tried but there is no success, and I'll try to dump tomorrow. And as you say, let us do good is yeast easier. be healthy
  7. #6
    Aug 2012
    Bulgaria
    [quote=LATTINO;1671264]
    Quote Originally Posted by plamen 63 View Post
    try with new dump
    Thank you for bothering to help on Alto unfortunately this dump of working again check lamp flashes. If you have new ideas I'm waiting. Greetings. Plamen
  8. #7
    Nov 2009
    Chile
    Default new dumps
    [quote=plamen 63;1674327]
    Quote Originally Posted by LATTINO View Post
    try these new dump for you primate car
  9. The Following 4 Users Say Thank You to LATTINO For This Useful Post:
    bearheroes (7th September, 2019), JAVBETT (27th August, 2022), johnie-9 (27th April, 2013), mr unlocker (27th September, 2023)
  10. #8
    Nov 2009
    Chile
    [quote=LATTINO;1675116]
    problem solved?
  11. #9
    Nov 2009
    Chile
    [quote=LATTINO;1676970]
    problem solved?
    There are people who begins to ask only for a help specify and then it goes away without saying not at least thank you.
    all regards
  12. The Following User Says Thank You to LATTINO For This Useful Post:
    speedservice (17th February, 2020)
  13. #10
    Aug 2012
    Bulgaria
    Default Yeah you're right
    Unfortunately the problem is not solved, but I delayed answer because I have a problem with my health. Alto it was very hard sbb t300 original and does not help you may need to look for the option Immo off or emulator. Once again I apologize for the delay but I had problems. Greetings. Plamen
  14. #11
    Nov 2009
    Chile
    the last are working dumps 100% and has your key matched
  15. #12
    Aug 2012
    Bulgaria
    Default Game over
    Hello Lattino saga is over and it passed in favor of your old car and prolong life anyway went for scrap. With your dump and started writing new sbb key with work. Thanks and thanks again. Be alive and well and helping people. Plamen
  16. #13
    Jan 2010
    EU
    please help synchronization ecu+immo suzuki alto
    THX
  17. #14
    Nov 2009
    Chile
    Default sincro
    Quote Originally Posted by carhelp View Post
    THX
    here you are
  18. #15
    gokey's Avatar
    Feb 2010
    hi
    have similar problem , suzuki alto 1996
    key lost
    read 24c01 to immobox but no data in dump !?
    need pair dump
    or other solution
