Hi everyone,
I got a problem with this skoda fabia 1.9 SDI , EDC 15 , 2004
I need some help here...please....
After the temperature is rising the car will start in 10-15-20 seconds of turning on the starter....
I mean the starter is ok , i can see clearly the RPM when hot, they are above 250, the battery is brand new...1 month old....
the only solution is to change something in software to give diesel at lower rpm when warm...think this should fix the problem....
When i unplug the wather temp sensor it's starting fine....i change 3 brand new sensors and still the same problem...
I attach the software here...
Thank you in advantage
