Results 1 to 3 of 3
    Aug 2012
    Default how to install dream elite 3-0 dm 800 clone
    HEI!
    When used flash wizard pro to install this img, then i get the a erroe message: this is not a valid firmware ??
    what do i wrong?
    DK Veteran billy2's Avatar
    Jul 2008
    some where over there
    is the img for a 800hd or the 800se ????
    please press the little red THANKS tab
    if I helped if not press the green tab to tell me to f**Koff
    sometimes life will kick you around , but sooner or later , you realize you`re a warrior , and your stronger than anything life throws your way !!!!!!!!!!!!!!!!!!!!!!
  3. The Following User Says Thank You to billy2 For This Useful Post:
    BIGLEE007 (21st June, 2013)
    Jan 2009
    Hi try unpluging your box , hold the standby button then power the box back up,shortly after it will say STOP in the screen and display an IP address , put this Ip address into your web browser and it will bring up the page to reflash the box from your pc via your wireless network.Hope this helps
