Page 10 of 51 FirstFirst ... 5678910111213141520 ... LastLast
Results 136 to 150 of 761
  1. #136
    einet's Avatar
    yes ATMEL.
    I important to change this cristal! this is not good i mesure my and see that the 12Mhz is not clean! when you have a ocxiloscope you can see what i say.
    is your LPt interface, wiggler or jtag OK? mybe you have problems with the 244 ttl?
  2. #137
    i have this interface:http://www.anvilex.de/extern/documents/DS_P009_06.pdf
    it's based on AHC125 wiggler and i think are ok.also have gq4x willem programmer with jtag adapter but don't try as not knew the setting for it.
    regards
  3. #138
    Quote Originally Posted by einet View Post
    My contribution for this helpful Thread!
    ...put a new cristal and condensators.
    I check mine, the three smd capacitors, with capacitance meter and found the values are as in the edited photo, maybe by their wrong assembled on mine. But yours all are 100nF?
  4. The Following User Says Thank You to Zmann For This Useful Post:
    ecufix (16th April, 2020)
  5. #139
    yes ATMEL.
    crystal changed,but nothing.74hc on wiggler changed,nothing.the only things what should moore change are the capacitors.
    moore ideas what should be?think that ihave try another pc/laptop with lpt to see if the error are not generated from pc side.
    regards
  6. #140
    autocargo's Avatar
    You can try on another PC. Wiggler not working on my laptop but working on my desktop.
  7. #141
    Quote Originally Posted by autocargo View Post
    that's i have already in mind,only when found one.owned 2 laptops and one pc,but only one laptop has lpt serial port on it.
    thanks.
    regards
  8. #142
    matekhr's Avatar
    Croatia
    Did anyone succeed to use wiggler using pcmcia to lpt interface?
  9. #143
    einet's Avatar
    Quote Originally Posted by Zmann View Post
    OHHHH.
    Good to now this values!, i make a more fine tuning to my CP
    thanks.
    P.S the fotos what i put there is not my CP, i only take this fotos to show my CP repair.
  10. #144
    Good to know more from you too. I think my instrument should be not so bad to read them (HP 973A DDM). And I also did a visual check by a magnifier, each of the three is with different apperance and slightly different in thickness. I think the right SMD should be around 100 pF. These are low quality ceramic chips without coding.
    The left one of 100nF is no problem, functioning of bypassing
    Middle and right, by looking roughly, are working together with the two IC's. So if the value not known I think the IC's datasheet may help in some of the way.
  11. #145
    Quote Originally Posted by sepistar View Post
    thanks.
    regards
    today try on another pc desktop,and wont write,interrupt on 2.20 sec with time out error.that will try another programmer based on hc244,and will see...
    regards
  12. #146
    Philippines
    Hi:
    Today I flashed my cp and all was ok till I tested on toyota dash now I have a message, could anyone help me with it please?
    My cp was working ok before.
    Thank you
  13. #147
    EARTH
    Default someone knows how to use J-link?
    TDO j-link acknowledges ARM.
    But not connect.
  14. #148
    Feb 2012
    polska/holandia
    choose the target-f9-target-Connect-target-f5, pin 55 upwards
  15. #149
    EARTH
    Default connection
    I am connecting as the photo.
    well this correct? for j-link.
    thanks...
  16. #150
    MACEDONIA
    Quote Originally Posted by audiotek View Post
    Here is your answer:
    I have two Carprog clone units, so, I take the risk and make all the reflash procedure without removing the AT88SC eeprom and the results are the same: the carprog unit works well after reflashing, the contents in AT88SC eeproms remains intact. I already make some tests with airbag modules, eerpom reading, some dashboards and mcu's and everything is ok.
    I flash my in that way and now my eeprom is erased
    Where to find eeprom contents for at88sc?
