Page 11 of 51 FirstFirst ... 67891011121314151621 ... LastLast
Results 151 to 165 of 756
  1. #151
    Member briangsm's Avatar
    EUROPE
    Quote Originally Posted by einet View Post
    My contribution for this helpful Thread!
    After ask that I have problems with my carprog "pin8 have short to power"
    I put hand on it and resolve this in the best way!.
    So the problem is I bay a CLONE-FROM-CLONE-FROM-CLONE!!! With vary bad pcb layer
    On the micro and in all pcb.
    First to resolve my pin 8 problem whose the missing line on button pcb side and the hole whose not connected!
    Restore all and pin 8 whose GONE GONE.
    Second not read MCU Motorola or I2C or 95...., change all 74HC125D to 74HCT125M put a new cristal and condensators
    And all missing resistors on my pictures and make the new connection on the power socket so that I have more space to close the carprog housing without bending the pcb.
    And in the last modification is that isolate type! Is necessary IMPORTANT!, carprog have a separate GND and when put
    The PCB back in the housing sometimes have problems in read some MCU or eeproms!
    So I find out that the pcb in one side from the regulators make connection to the housing and make in
    The same time short to the another side from the PCB!
    Final Result
    Without put double 74HC125M (8x) to read I2C or 95 or MCU without or with external power
    My carprog read all without external power.
    Thank's great job
  2. #152
    audiotek's Avatar
    May 2011
    Quote Originally Posted by whiskymk View Post
    I flash my in that way and now my eeprom is erased
    Where to find eeprom contents for at88sc?
    I already reflash my carprog 4 times without remove the atmel and I don't have any problems until now, works well with eeproms and mcu's, some problems with dashboards and airbag mdules, just like xprog-m clone: sometimes you need to try 2, 3 or 4 times to read/write or verify. BR...
    Xprog Box Original, UPA Original, GromCalcTool,TL866A, Willem PCB50, Masterprog, NecProg, Orion, Ponyprog, Carprog, Renesas H8SX, MT60/80, SPC560 programmers,Obdstar X300DP, EZ500, CHIPSOFT MID,SKP1000,Cantool, SuperVag 3.0, Vag Commander, Vagcom Original, Launch x431 Pad, Witech OEM, Ford VCM II OEM, Mazda VCM II, Volvo Vida-Dice, Hyundai & Kia GDS, MUT III, Mastertech VCI, EASE j2534, Ford & Mazda VCX, TS401, Cardaq-m, DIS 5.7, VAS5054 Plus, Tachopro 2.0 & 2008.01, Vag K+Can, JLR v141.....
  3. #153
    Oran - Algeria
    Hello where can buy a jtag programmer
  4. #154
    Jun 2012
    Making procedure of programming MCU carprog counter will return or no?
  5. #155
    Dec 2012
    hello!
    i must use Jtag programmer:?
  6. #156
    EUROPE
    Default Re: Carprog Mcu Reflash Step by step
    after reprograming Return counter today my cp clone show counter 250
    Sent from my GT-I9001 using Tapatalk
  7. #157
    autocargo's Avatar
    Yes, counter will always return...
  8. #158
    DK Veteran buga37's Avatar
    USA
    Quote Originally Posted by autocargo View Post
    yeap, just did on my today, need to reflush it again
  9. #159
    EUROPE
    other carprog clone damage no device attached how repair green led lighting i reprogaminig at191 no efect komputer no detect device
  10. #160
    Mar 2013
    BONJOUR
    j'ais mis une mise a jour et mon carprog c'est bloquer
    J'ais realiser un jtag et connecter carprog comme indique ,dans h flascher il trouve le target arm7TDMI LITTLE ENDIAN?MAIS PAS LA FLASCH,
    j'ais un message d'erreur
    qui peut m'aider
    cordialement
  11. #161
    Mar 2013
    bonjour
    PROBLEME RESOLU
    dans configuration ,j'ais regle init tcp sur 1MHZ et pgm tck 1Mhz,la flasch est reconnu
    j'ais pu envoyer le fichier ,remis l'eeprom et ca roule
    note ; meme avec la patte 55 DU MCU non resouder ,ca marche (je l'avais oublie ),je l'ais
    quand meme mis a la masse pour eviter de futur lezard .
    cordialement
  12. #162
    Youneselm's Avatar
    Nov 2010
    bien fait.......
  13. #163
    Oct 2012
    merci pour l info
  14. #164
    Tereksaz's Avatar
    Nov 2010
    Dark side of the Moon
    I want to change serial number CAR prog.
    I make change, add new lib file.
    Run.
    select any , for example airbag.
    Software says - bad CRC!!!
    but idont know, how calculate crc !
    Anybody know?
    How can me do it?
    Tereksaz
  15. #165
    GREECE
    Anyone have experience about carprog OR this UltraProg:??
