Xprog Box Original, UPA Original, GromCalcTool,TL866A, Carprog, Renesas H8SX,Obdstar X300DP, EZ500, CHIPSOFT MID, Vagcom Original, Witech OEM, Ford VCM II OEM, Mazda VCM II, Volvo Vida-Dice, Hyundai & Kia GDS, MUT III, Ford & Mazda VCX, TS401, Cardaq-m, VAS5054 Plus, JLR , Cardaq 3 Plus, Launch x431 Pro3, Renault Can Clip, VVDI prog, Autel iM608, GM DPS, CDA6, Nissan Ners, Consult III Plus, Techstream, Honda HDS and iHDS, MMC flasher, Mazda MDS, Forscan, HP Tuner, Miniprog.....
Yea friend cracked 88 (think he just figured out from at and add to at his board works without 88). I gave a copy of one of his soft to a close friend and it got leaked and does not trust anymore.
perfect- works 100%
fluorescent (25th April, 2019)
hi,
work with convert usb-port parallel ?
Friends, is any of us has a newer .lib file than v4.01??? Because, if you just reflash HW it means nothing without changing .lib file...a new SW will work (ok, counter will be reseted) but all new functions will be NA marked
cuby
hello,
I bought jtag on ebay. with parallel converter usd.
JTAG programmatore | eBay
but I can not connect.
the jtag, it works with the convertirore usb?
No, but heard that the perfect one does but, again, it's much more expensive than your jtag.
hello is look from chines compagny but look is
CARPROG FULL V5.31(with all Softwares activated full Adapters) is the newest version of carprog in 2013, more car models than v4.01, and add count reset cable
it is can
CarProg can be full reflashed over USB even is locked with counter "0" ;-)
Regard's
[I]Automotive Electronics Solutions
Mercedes-Benz Reverse Development Engineer ...
Mercedes CFF 2010-2017 CFF all models all modules
Vediamo help flashing over teamviewer ...
JLR SDD online + offline ...last official ...
PierreTheron (13th October, 2013)
Can you be more specific?
Does anybody know if it is possible to update the firmware of a clone CARPROG FULL V4.01 to work in software V4.74 and even V5.31. The new versions of software in these clones really are FULL?
I have tried to reflash with ULINK2. Connected successfully , but it supports only hex files. Maybe someone can give me hex file of AT91SAM7s256 or convert it from bin? Thanks
Anyway I have converted by myself. So if anyone will need hex file of carprog, here you go. AT91SAM7s256.zip
BimmerGT1 (27th August, 2013), blaneslectronica (23rd May, 2016), Grucha1982 (24th September, 2016)
