Page 19 of 51 FirstFirst ... 9141516171819202122232429 ... LastLast
Results 271 to 285 of 761
  1. #271
    Friends; i have this problem to conect to MCU
    Unknowon Target. Please update the target list via target manager, or try to designate the target manually.
    ???? cant connect mcu with h-jtag
  2. #272
    Did you erase the mcu before try to connect?
  3. #273
    http://www.digital-kaos.co.uk/forums...p-step-288814/
    "Wait from 5 to 10 seconds after connect the 12v supply, the flash content will be erased and the Jtag option of the Mcu will be enabled now. If not work leave connected for about 3 to 5 minutes. Disconnect the 12v supply from carprog and remove the pin 55 wire from vcc. The pin 55 must remain disconnected until the programming process is done."
    BR
  4. #274
    Jun 2012
    If no erase right MCU no have conection with MCU
  5. #275
    thanks guys for your answers, the problem was with the long cable programmer.
    regards
  6. #276
    martij976's Avatar
    Do You guys realize how much time U spent on that?
    Is cheap clones really worth this??
  7. #277
    AKAINTERN's Avatar
    Dec 2012
    is the server (h-jtag) to determine if the Target 55 pin to ground and the at91sam is not erased?
    I want to test the J-tag board on 5 resistors before erasing the at91sam !
  8. #278
    AKAINTERN's Avatar
    Dec 2012
    today lifted the 55-pin from the board, the h-jtag server still does not find the Target.
    as it should be if at91sam not erased?
    Who can check this on your carprog?
    whether defined Target at91sam if not erased?
  9. #279
    DK Veteran zeljolaki's Avatar
    In my garage
    Quote Originally Posted by AKAINTERN View Post
    If, after connecting the USB, your computer does not recognize the device-processor is erased if genes recognized as you see serial number -processor dont erased!
  10. The Following User Says Thank You to zeljolaki For This Useful Post:
    leonida (17th August, 2018)
  11. #280
    antwnhszr's Avatar
    macedonia is greek....
    good morning dk's.after the read the AT88SC with beeprog 2 , the carprog die....divice not found...any solution?
    thank you all..regard's
  12. #281
    autocargo's Avatar
    Quote Originally Posted by antwnhszr View Post
    Only if you can get hold of at88 dump... I don't have it...
  13. #282
    antwnhszr's Avatar
    i have the dump m8 from AT88SC i write again but nothing done.........
  14. #283
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    the AT91SAM7S256 can be programmed with upa 1.2?
  15. #284
    autocargo's Avatar
    Quote Originally Posted by jomberykaso View Post
    No it can't.
  16. #285
    maybe you must set the sec. bits
